1$\begingroup$ Are you asking about a 90 degree crosswind specifically, or any crosswind? $\endgroup$– GdDApr 7, 2021 at 9:07
$\begingroup$ Yes, 90 degree crosswind. $\endgroup$– GreyApr 7, 2021 at 9:15
$\begingroup$ Any crosswind is the sum of a sideways, 90º component and a component parallel to the runway. In other words, any crosswind has a 90º component... $\endgroup$– xxavierApr 7, 2021 at 9:49
3$\begingroup$ @xxavier Yes, but it's possible, in a direct crosswind, for the parallel component to be zero. That's what the OP is asking about. $\endgroup$– HiddenWindshieldApr 7, 2021 at 14:06
1$\begingroup$ @Criggie -- consider also -- if in a sailboat, you'd rather have a 90-degree crosswind than no wind -- :) $\endgroup$– quiet flyerApr 7, 2021 at 22:42
The effects of a constant crosswind up to the demonstrated value are insignificant (at least for airliners), as ymb1's answer already says. I checked some Boeing FCOMs and crosswind is never mentioned for takeoff performance calculation. It can therefore not have a significant impact. Boeing recommends this technique:
Any deviation from the centerline during thrust application should be countered with immediate smooth and positive control inputs. Smooth rudder control inputs combined with small control wheel inputs result in a normal takeoff with no overcontrolling. [...]
Note: Excessive control wheel displacement during rotation and liftoff increases spoiler deployment. As spoiler deployment increases, drag increases and lift is reduced which results in reduced tail clearance, a longer takeoff roll, and slower airplane acceleration.
[emphasis mine]
A gusty crosswind may however require larger control wheel inputs, which result in spoiler deployment. This will impact takeoff performance. Boeing therefore recommends to use more than the minimum required thrust in these situations:
For takeoff in gusty or strong crosswind conditions, use of a higher thrust setting than the minimum required is recommended. When the prevailing wind is at or near 90° to the runway, the possibility of wind shifts resulting in gusty tailwind components during rotation or liftoff increases. During this condition, consider the use of thrust settings close to or at maximum takeoff thrust.
Source: Boeing 737 NG FCTM 3.15 - Takeoff and Initial Climb - Crosswind Takeoff
Only the head- or tailwind component affects the takeoff performance:
The crosswind component does not affect takeoff performance. Nevertheless, it is necessary to demonstrate the safety of takeoff and landing procedures up to 25 knots of crosswind. The maximum demonstrated value must be published in the Aircraft Flight Manual.
— Airbus Flight Operations. "Getting to grips with Aircraft Performance." (2002).
To the downvoters and commentators, if you have a measurable effect, published in manuals, do post an answer.
8$\begingroup$ I do not believe this answer is precisely accurate when rudder is used during takeoff. Rudder should cause drag, reducing performance. $\endgroup$ Apr 7, 2021 at 11:05
5$\begingroup$ In many aircraft the correct crosswind technique is to start with full aileron deflection into the wind, and then reduce that deflection as aircraft velocity increases. It would seem that the period of full aileron defection would have an increased drag component until approximately the time the airplane became airborne, at which the slip would transition into a crab. $\endgroup$– mongoApr 7, 2021 at 12:59
2$\begingroup$ I suspect that the quote from Airbus Flight Operations, while relevant to the answer, is an oversimplification and not completely correct. $\endgroup$ Apr 7, 2021 at 13:15
2$\begingroup$ @quietflyer: Fine. Again, what is the measurable effect? $\endgroup$– user14897Apr 7, 2021 at 13:19
4$\begingroup$ @ymb1, it was measurable enough for us during a test flight series I flew, and was included in the aerodynamics modeling. The impact was on takeoff roll, and not, obviously, on takeoff climb performance. But it did impact the overall take off roll, and the climb over obstacle, and was a concern during the STC process for our operations. So I mention it because it is real, even though a flight manual may decide to omit it. $\endgroup$– mongoApr 7, 2021 at 13:35
To analyze the impact of a crosswind takeoff on performance, it is necessary to break down the effects on each phase of the maneuver. For simplicity, let's examine a single engine trainer type aircraft, and see where the crosswind impacts takeoff performance.
At the start of the takeoff roll, with a crosswind, full deflection of aileron is made into the wind. This presents increased drag because both the left and right aileron are in a high deflection position. Of course, at the initial takeoff roll, the drag is minimized because of the low airspeed. As air speed increases, the deflection is reduced, which will have a limiting effect on the aileron drag, but that drag is still present, measurable and duplicatable. Additionally, while rudder is used to maintain directional control, and counteract asymmetrical propeller trust, it is also being used to effectively maintain an aerodynamic slip while on the ground. Slips create increased drag, and slightly more power is consumed by the slip, being a combination of aileron input, rudder input and side forces on the fuselage.
After the plane departs the runway, the slip can transition to a crab, and the power losses associated with a slip disappear, as the aircraft is now in coordinated flight.
The impact on a crosswind takeoff, assuming the above technique, is on the takeoff roll, where the aircraft is in a slip. The longer takeoff roll will increase the amount of runway used for the roll. However, the climb out performance will not be affected adversely by the crosswind. In fact the aggregate wind vector on the aircraft will be influenced by the crosswind, and may result in a higher "head wind" vector which would reduce the distance to clear an obstacle, or to get to altitude.
A simple summary would be the crosswind takeoff adversely impacts the runway roll, and the initial climb to clear a near obstacle such as power lines at the end of the runway. However, the distance to climb to altitude may be reduced by some small amount. Climb rates are affected by power and once the power lost by the slip during the ground roll is regained, the aircraft will perform normally.
Both of these effects are readily model-able. Effects will of course be greater on slower aircraft, such as motogliders and trainers. The effects will be lost in the noise (no pun intended) on high performance aircraft such as fighter jets.
