I understand the delta wing was chosen because of the supersonic cruise (like the Concorde), and canards were added to reduce the approach/landing speed. But canards may be used without delta wing (e.g. Focke Wulf F-19, Soukhoï Su-47, Rutan Voyager,...), so I don't understand why the canard wing configuration is not used among commercial aircraft.
1$\begingroup$ Would it be helpful to add an image of the mentioned aircraft? $\endgroup$– dalearnDec 8, 2017 at 19:02
$\begingroup$ The FW-19 "Ente" was designed exactly for the purpose of testing wether a canard is the better choice for a commercial transport airplane. As it turned out, it wasn't. That settled the discussion and newer designs merely confirmed what had been found out back then. $\endgroup$– Peter KämpfJun 13, 2020 at 7:15
Short answer: Canards make most sense with negative static stability and high maneuverability. Commercial aircraft don't need either, so a conventional layout works best.
For a statically stable aircraft, the conventional layout gives most efficiency with sufficient damping. Static stability requires that the forward lifting surfaces create more lift proportionally to their size than the rear surfaces. Here is an answer to a related question.
You want the airplane to return to the original flight attitude if it has been disturbed, say by a gust or a jolt on the stick. This can be done by creating proportionally more lift with the forward surfaces (= the wing in a conventional configuration) than with the rear surfaces (= the wing in a canard configuration). Say the jolt pitches the aircraft up. Now the aerodynamic forces should change in a way which increases lift proportionally more on the rear surfaces, so the aircraft pitches down and returns to it's original attitude. By distributing lift the way I mentioned above, the same change in angle of attack on both forward and rear surface will create a proportionally higher lift increase on the rear surface, making the aircraft (statically) stable.
That requires that one of the (mostly) two surfaces is not contributing as much to lift creation than it could. You want this surface to be the smaller one of both, so the whole configuration can create as much lift as possible at a given speed. A canard would be a poor choice for a commercial airplane, because the big wing would now fly at a fraction of it's potential.
Once you shift the center of gravity back to improve maneuverability, things get different: Now the rear surface is creating proportionally more lift, so the smaller surface should go in front. Voilá, a canard!
Now add forward sweep, which will make the wing tips twist to higher angles of attack when lift is increased, and you get a really responsive aircraft (but need to be careful not to overstress it!). This was done on the X-29 and the Berkut.
As jwenting pointed out, the canard on the Tu-144 was not a control surface, but should be considered a detached slat of sorts. Also, by adding some lift ahead of the wing it allows to lower the wing flaps in slow flight, increasing the lift potential of the main wing while maintaining the location of the center of gravity and stability.
And while we are at it: The Piaggio Avanti has a canard, and a conventional tail, too. Here the canard helps to put the wing spar behind the cabin area, makes it easier to fly with a wide range of c.g. locations and to increase aerodynamic damping. This is one of very few examples in commercial aircraft of canards done right!
2$\begingroup$ You state that the conventional layout is the most efficient for a statically stable aircraft. So I guess this begs the question of why commercial aircraft continue to require static stability: is anything else considered too unsafe, even for cargo airplanes, and even if there are significant efficiency gains? I feel that is a major part of the original question. $\endgroup$– RomanSep 22, 2014 at 1:55
4$\begingroup$ @romkyns: Stricly speaking, natural static stability is not necessary if the FCS works. Also, an aircraft is still flyable with reduced stability, and if an unlikely failure means a limited workload increase for the pilot, reduced but still positive stability would be in line with current certification standards. But even then the canard would still be worse than a standard configuration. And consider this: I spoke around 1990 with A-310 pilots who flatly refused to ever fill up the tank in the empennage, because they wrongly believed this would make the plane instantly unstable. $\endgroup$ Sep 22, 2014 at 7:11
The canards on the Tu-144 weren't canards technically. They were static surfaces, not moving.
They were purely lift devices to improve low speed handling (and thus help reduce landing speed which was excessively high).
These were added because low speed handling was found to be deficient, due to the inferior (as compared to Concorde) wing design.
3$\begingroup$ @slebetman jwenting's avatar leads me to think that he know about canard tho... $\endgroup$– AntziFeb 22, 2018 at 7:23
$\begingroup$ It wasn't the wing that was the problem (if anything, it was probably superior to Concorde's aerodynamically, and in any case had significantly lesser loading); rather, it was a combination of design decisions with closely packed engines and shorter landing gear. This made Tu more susceptible to tail strikes and greatly limited its landing attitude. Thus folding canards were added so that flaps could be used. $\endgroup$– ZeusNov 1, 2018 at 7:53
1$\begingroup$ @Zeus the wing was a problem for low speed flight. At high speeds it was indeed very good. The factors you mention of course didn't help. $\endgroup$– jwentingNov 1, 2018 at 8:08
$\begingroup$ @Antzi I don't know what jwenting's avatar at the time of posting was, but the current avatar might lead one to believe there is extra insight into mallards, not canards. $\endgroup$– T.J.L.Aug 6, 2020 at 14:10
Because it is not aerodynamically efficient. To achieve stability the forward surface has to fly at higher angle of attack than the rear. So the canard has to fly at rather high angle of attack which leads to high drag and disrupts airflow for the main wing further reducing it's efficiency. It is not a chance that most modern jets have the same layout. It is most efficient known design.
Also while the higher angle of attack of the canard leads to it's biggest advantage, the gentle stall behaviour where the aircraft just gently lowers nose it means that the maximum usable angle of attack is reduced. This increases landing speed and reduces the safety margin should the aircraft get caught in a wind-shear. Suitable wing twist provides not much worse stall behaviour without these disadvantages.
With delta wings, the canard has advantage that it increases stall angle of attack and thus maximum lift, because the canard acts as vortex generator. This means sharper turns at high speed and lower landing speed, which is why this configuration is popular in fighters (Eurofighter Typhoon, Dassault Rafale, Saab JAS-39 Grippen) where manoeuvrability is more important than efficiency. Besides these designs are not stable (stabilized by computer instead; allows faster control response), so the canard does not produce that much drag.
The Sukhoi Su-47 uses canard primarily for layout reasons as the forward-swept wing does not leave much room at the tail, but a lot of room at the nose. And it's not clear how good the layout actually is; it does not seem to be followed by other military designs. Grumman X-29 first flew in 1984, but no follow up design was created.
The Rutan Voyager counters the inefficiency by not flying the canard at high angle of attack, which yields good efficiency, but poor pitch stability. It was manageable for good test pilots, but not suitable for average airline pilot. And note that this also eliminates the stall behaviour advantage of canard.
1$\begingroup$ OK for the test pilots skill superiority, but nowaday almost all new commercial aircraft are fly-by-wire with computer stability enhancement. $\endgroup$– Manu HSep 9, 2014 at 14:42
$\begingroup$ @ManuH: The fly-by-wire actually reduces stability if it does anything to it. Airbus FBW makes the aircraft artificially neutrally stable, but aerodynamically the aircraft are still positively stable so it can be flown with the mechanical backup. And Airbus is alone (Sukhoi copies it in Su-100, but that's the only I know of); Boeing FBW only provides flight envelope protection, but leaves stability unaffected. $\endgroup$ Sep 9, 2014 at 15:10
$\begingroup$ @ManuH: Of course military aircraft are a different matter. New fighters are almost always aerodynamically unstable and their FBW enhances stability (added complication is that supersonic aircraft are more stable in supersonic regime, so if they want to be highly manoeuvrable at supersonic speed, they end up unstable at subsonic). But it's not the case of any transport aircraft. $\endgroup$ Sep 9, 2014 at 15:13
1$\begingroup$ @ManuH, you're covering a lot of ground in a few words: "...nowaday almost all new commercial aircraft are fly-by-wire with computer stability enhancement." "The fly-by-wire actually reduces stability if it does anything to it." "Boeing FBW only provides flight envelope protection, but leaves stability unaffected." Slow down, indicate precisely what you mean to say. $\endgroup$– Bill IVSep 11, 2014 at 1:16
