So I know that you can legally buy and fly a military jet like the Mig-29 and the SU-27 https://www.wired.com/2010/01/own-the-coolest-jet-on-your-block/ and https://www.thedrive.com/the-war-zone/29292/you-can-buy-paul-allens-mig-29-fulcrum-jet-fighter. But practically can you fly it? I mean how high can you climb? How fast can you go (I know no supersonic flights are allowed above land, but what about sea)? Can you do barrel rolls and pull Gs? Also, can you use it to fly internationally (assuming that you can attach external fuel tanks in the first place)? Can you actually have fun with it lol? Assume that money is no issue.
Sure.
As high as you want, assuming you have an oxygen delivery system (14 CFR 91.211, note that "civil aircraft" means "any aircraft not a public aircraft" means "any aircraft not owned by the government," so you can't get out of it that way) and assuming both you and the plane are certified for IFR flight (14 CFR 91.135).
Below 10,000 MSL no faster than 250 KT, and below a Bravo shelf or near a Charlie/Delta airport no faster than 200 KT, unless the minimum safe airspeed for the aircraft is higher than that (14 CFR 91.117). For supersonic flight see 14 CFR 91.817, 91.819, 91.821.
Assuming the aircraft is certified for aerobatic flight (or perhaps if it has an experimental certification), yes, as long as you comply with the restrictions in 14 CFR 91.303; or failing that, submit an application for a waiver of Part 91 rules (FAA Form 7711-2) (see also) and get such a waiver.
Yes, if you comply with each country's respective airspace/border entry rules.
Depends what you think is fun.
Basically there are no special rules for ex-military aircraft; if you can legally get your hands on one, and if you can legally fly it, you can do whatever any other aircraft is allowed to do as long as you follow the rules any other aircraft has to follow.
  • $\begingroup$ "Basically there are no special rules for ex-military aircraft" I'm not sure this is entirely true. Typically to be able to fly recreationally, they need to be certified or experimental, which means that they really can only be certified under "experimental / exhibition". This places a lot of restrictions on what you can do with them... $\endgroup$
    – Ron Beyer
    Mar 15, 2021 at 0:30
  • $\begingroup$ @RonBeyer Fair point, let's say "There are no special rules for ex-military aircraft beyond the restrictions placed on any other experimental aircraft." $\endgroup$
    – randomhead
    Mar 15, 2021 at 0:33
  • $\begingroup$ Thanks a lot... $\endgroup$
    – boodo17
    Mar 15, 2021 at 0:36
  • $\begingroup$ Well... it's a clear day & you can fly VFR below 18,000' and do acrobatics in anyplace sufficiently away from airways & airports & such things. BUT, what if you want to do acro up into what's normally the flight levels??? The military has MOA's and restricted areas to do exactly this; how can a civilian jet get access to a block of airspace he's allowed to use & maneuver in that extends above 18,000'? Is there a way to coordinate that with ATC (in advance) for specific lateral limits up to some specified higher altitude? $\endgroup$
    – Ralph J
    Mar 15, 2021 at 0:48
    $\begingroup$ @RalphJ IFR aircraft can request a 3D block of airspace for maneuvers. The details of how is a new question. $\endgroup$
    – StephenS
    Mar 15, 2021 at 3:04
