12
the jet engine FJ33 produced by Williams International produces around 6 kN thrust (maximum, at sea level).
Imagine: to fly supersonic, I need for my aircraft 9 kN of continious thrust.
I am wondering now: is it possible to use just two FJ33 jet engines, so that I would just double the maximum thrust ?
What are the restrictions to this?
My thoughts: If I fly supersonic with a jet engine which is designed actually for subsonic flight, there can be many aerodynamic effects like stall and strong rise in drag at the gondola, for which the engine is not designed: So I would need a diffusor to bring the supersonic flow down to an optimal flow velocity for the FJ33.
Is this correct? Do you know some other restrictions?
    $\begingroup$ When you calculated 9 kN of thrust required, that calculation worked from some assumed aircraft weight and size... more thrust required to push the Concorde supersonic than for an F-16. Adding another engine changes the weight & size & shape of the aircraft. So the new aircraft will probably need more than 9 kN to go supersonic. Add enough motors (with proper inlet/exhaust geometry & etc) and you'll have enough thrust, but the resulting tradeoffs (range, payload, etc) may make the final design pretty different than what you started with. $\endgroup$
    – Ralph J
    Mar 11, 2021 at 16:14
  • 7
    $\begingroup$ Not seeing the cause for downvotes. As an entry-level, conceptual question, this seems to be reasonable. "What's so hard about going supersonic, just add more engines, right?" Clearly it's not that simple, but let's explain why not. $\endgroup$
    – Ralph J
    Mar 11, 2021 at 16:28
    $\begingroup$ Does this answer your question? How is supercruise achieved? $\endgroup$
    – user14897
    Mar 11, 2021 at 16:33
    $\begingroup$ @Ralph J, good point, but I downvoted it because it doesn't read like a well thought out conceptual design question. It reads like "I want to bolt an extra jet engine on MY AIRCRAFT to see if I can fly supersonic." (The image that comes to mind is the infamous Darwin award winner who strapped a JATO bottle to his car...) $\endgroup$ Mar 11, 2021 at 16:34
    $\begingroup$ Personally, I would be more concerned with "Will my airframe disintegrate if it reaches supersonic speeds?" than "Will strapping an extra engine onto my airframe allow it to achieve supersonic speeds?" You might be able to achieve supersonic speeds even without an extra engine, simply by entering a steep dive in a clean configuration with max thrust selected. But your airframe also might disintegrate if it isn't designed for supersonic flight. $\endgroup$
    – reirab
    Mar 12, 2021 at 5:08
4 Answers 4
19
Yes, you will double the maximum thrust on the ground and at rest. You will also double thrust at altitude and flight speed, but that thrust will be much lower than your sea level static thrust. Below is a thrust diagram over speed and for several altitudes for a small turbofan engine with a bypass ratio of 3. It is not the Williams, for which I don't have this kind of diagram, but very similar.
Turbofan thrust diagram
The kink in the low level thrust line is from internal engine pressure limits. At low altitude and high speed the pressure inside the compressor and burners must be limited so they will not be overstressed.
Below 10,000 ft it is not legal to fly faster than 250 kts and supersonic flight is illegal over a lot of areas. In order to achieve legal supersonic flight you need to be high and over unpopulated land. The higher the better, but as you can see from the diagram, thrust drops with altitude. For turbofans it also drops with airspeed. Now it would be interesting to know at what altitude and speed those 9 kN of thrust are required - maybe that number is for a lower altitude and the two FJ33 are indeed sufficient. At the moment that question is unanswerable with the information given.
Yes, but that is simpler than it seems. Every engine intake will slow down and pre-compress the incoming air stream at high subsonic flight speed simply because the engine will not be able to swallow all the air that could flow through the intake at high speed. Instead, some air will spill over the intake lips so only the core of the streamtube that flows toward the intake will be ingested. At supersonic speed the intake will do this precompression by means of a shock, the strength of which is again influenced by the swallowing capacity of the engine. Still, the intake cross section needs to widen between the intake face and the engine face and must be carefully shaped to avoid flow separation or speed variations at the engine face (that is actually the tricky part) or you will not be able to achieve the full performance of the engine. A simple pitot intake should be sufficient but it will need some length to do its work properly. Therefore, it is advisable to not put the engine in gondolas (B-58 style, also called nacelles) but to integrate them into the fuselage.
Thrust is the difference between intake an exit impulse, so you need high exit speed in order to have useable thrust at supersonic speed. While a simple convergent nozzle can be used to achieve supersonic flight, the best results are obtained with a convergent-divergent nozzle. Due to the high temperature of the exit flow, even a subsonic exhaust stream will bring you to supersonic speed, but only just. Given the relatively high bypass ratio of the FJ33, if supersonic flight is achieved, the maximum Mach number in level flight will not be much above 1 (if the drag characteristics of the airframe allow even this).
  • $\begingroup$ Great answer Mr Kämpf, thank you, helps me a lot ! $\endgroup$
    – Lucas
    Mar 12, 2021 at 8:31
  • $\begingroup$ Digression - It is not illegal to fly fast and low, it just requires permission. Large commercial aircraft would normally climb at V2+100 and at load, that can easily exceed 250Kts. The controllers know this and don't hesitate to grant permission. $\endgroup$
    – Paul Smith
    Mar 14, 2021 at 21:17
  • $\begingroup$ @PaulSmith The linked answer says the same, but I selected a very brief and necessarily imprecise term. $\endgroup$ Mar 15, 2021 at 5:00
14
There are actually two questions in this post, which I'll address separately.
The first question is "Does the thrust from multiple engines add together?" And the answer to that is yes, so long as both engines are mounted so that their thrust vectors are parallel, two engines, each producing 6 kN of thrust, will produce a total of 12 kN.
The second question is "Can I just bolt a second engine onto my airplane to make it go supersonic?" There's not enough information here to accurately answer that question, so the closest I can get is "probably not".
The maximum thrust of the engine doesn't matter. What matters is the actual amount of thrust produced by the engine in the conditions you expect. You mention the maximum thrust is achieved at sea level. But you're not likely to be flying at sea level, are you? You're going to be flying much higher, where the air is thinner and therefore wind resistance is much less, but you're not going to get the full 6 kN at those altitudes. An engine designed for subsonic speeds also isn't going to produce its maximum rated thrust at transonic or higher speeds, so you're also going to lose thrust as your speed increases.
There are other factors too. There are all sorts of interesting shock waves that form in the transonic region, which could either starve your engines of air, force too much air into them, or even damage the turbines. Adding baffles as you mention is going to add a lot of drag, which will need more thrust to counter. Another consideration is that the simple weight of the engine will require more thrust to lift. So even if your "9 kN" calculation is accurate for the plane as-is, it's not going to be accurate after you've made all these modifications to it.
Another thing to consider is the strength of the airframe. If you put a second engine on a frame not designed for it, you're going to damage and probably destroy it.
  • $\begingroup$ Thank you hiddenWindshield! $\endgroup$
    – Lucas
In general, the answer is no. The two classes have different characteristic exhaust velocities. However, some subsonic engines can be persuaded to attain modest supersonic speeds.
A subsonic turbofan, such as the Williams FJ33, is designed for maximum efficiency at subsonic speeds. It therefore has a high bypass ratio, meaning that the fan greatly increases the mass flow of the engine, while limiting the overall exhaust velocity. This maximises the thermodynamic efficiency of the engine, and hence also its fuel efficiency. The exhaust nozzle is shaped to allow air out without building up a back pressure which would reduce mass flow. Typically it is of convergent profile, which accelerates the exhaust backwards and thus converts some of the exhaust temperature and pressure into thrust.
A supersonic engine has to accelerate the exhaust much harder. To obtain a given thrust, it therefore needs less mass flow and so its bypass ratio is much lower (a pure jet has zero bypass ratio). But supersonic airflow within an engine, especially its "hot" end, is undesirable. So, to maintain high exhaust speed the temperature of the exhaust is raised, also raising the speed of sound in it. The exhaust thus "thinks" it is still subsonic. The exhaust nozzle is shaped to maintain the back pressure needed to maintain that temperature, but still somehow provide additional thrust. It is typically of convergent-divergent profile; the convergent section helps to retain the back pressure, while the high-pressure exhaust passing from there into the divergent section then expands rapidly sideways, its pressure thrusting against the angled sidewall to create significant thrust.
So you can see that merely adding a supersonic intake duct is nowhere near enough; subsonic turbofans such as the FJ33 are just not cut out for the supersonic role, their low exhaust velocity prevents anything more than the most modest supersonic speeds. You might in theory add an afterburner (reheat) and reshape the exhaust nozzle, but that would massively increase fuel consumption. The performance and reliability of the engine core would also suffer, as it would not be optimised for such a pressure and temperature regimen.
  • $\begingroup$ Great answers, thank you, helps me a lot ! $\endgroup$
    – Lucas
Another important thing to bear in mind is that aerodynamics work quite differently at supersonic speeds. While you can make anything go fast if you push hard enough, an aircraft that’s not designed for supersonic operation would likely be uncontrollable under those conditions.
    $\begingroup$ That is well worth to be considered. For the nitpickers: This is a valid answer, because it addresses the "simply" in the question. No, supersonic flight is not made possible by just simply adding more thrust. $\endgroup$ Mar 12, 2021 at 20:58
  • $\begingroup$ @PeterKämpf "No, supersonic flight is not made possible by just simply adding more thrust." Well, not just by adding more thrust, using air-breathing engines. If you're using rockets, "more thrust" is likely to suffice. $\endgroup$
    – nick012000
    Mar 14, 2021 at 15:05
  • $\begingroup$ @nick012000 Momentarily maybe, but not in a sustained way if you cannot trim the changed lift distribution at supersonic speed. Add to that new forms of flutter and aeroelasticity and sustained supersonic flight turns out to be non-trivial. $\endgroup$ Mar 14, 2021 at 16:22
