I made this simple wing glider and put some ailerons on it. I thought that the ailerons in this glider would work the same way it works on airplanes, wherein the roll will be in the direction of the aileron that is pulled up. However, the opposite happens. For example, when I pull the left aileron up and the right aileron down, instead of rolling to the left, it rolls to the right. What is the reason behind this? And what is the difference between the control of this flying wing to a conventional airplane?
2$\begingroup$ Could you film it? $\endgroup$ – Abdullah Feb 24 at 11:17
11$\begingroup$ Silly question perhaps, but is the stick the nose, or the tail? $\endgroup$ – Jamiec♦ Feb 24 at 11:31
4$\begingroup$ Just a wild guess (hard to tell from your picture) - the down aileron is likely adding a ton of drag to the right side. Try bending it down 1/2 the amount you're doing now. $\endgroup$ – Dan Pichelman Feb 24 at 12:05
$\begingroup$ Not unrelated -- aviation.stackexchange.com/questions/47514/… , aviation.stackexchange.com/questions/47514/… . Of course, the paraglider doesn't actually have dihedral like your model airplane does, but it acts like it, due to the "pendulum effect" ( aviation.stackexchange.com/questions/53437/… ) Btw, the Gossamer Albatross ( en.wikipedia.org/wiki/MacCready_Gossamer_Albatross ) also used "wrong-way" ailerons. $\endgroup$ – quiet flyer Feb 24 at 21:20
Most likely the adverse yaw effect (due to the induced drag of the increased lift on the down-aileron side) is causing the wing to yaw the opposite direction from the intended roll, and the yaw causes the dihedral induced roll (proverse to the yaw) to override the aileron input.
This situation is very commonly seen with very slow flying model aircraft -- indoor Peanut scale, for instance, or Penny Plane models, will often be set to turn left by putting a relatively tiny tab under the left wing, where you'd expect the lift to cause a roll to the right.
In some aircraft, such as the Canadair CP-107 Argus, the control yoke is not actually connected to the ailerons. Rather, they are connected to servo tabs, which are basically small ailerons attached to the rear of the actual ailerons (not to be confused with trim tabs, which look exactly the same but are controlled differently). Turning the yoke left causes the left servo tab to angle down, which deflects the actual aileron up. The aileron deflects the air stream upward, pushing the left wing down. The opposite happens on the right aileron and tab, raising that wing.
This effect can also occur unintentionally. For example, the Boeing B-47 Stratojet couldn't fly faster than 425 knots; above that speed, the ailerons would twist the wings so much that the airplane would roll in the opposite direction from what the pilot commanded.
I think it's likely that you're experiencing this. It's possible that the upward-turned aileron is twisting the whole wing downward enough that the plane rolls in the opposite direction from what you wanted. If that's the case, your options are to either stiffen the wings somehow, or just accept that your ailerons are going to work in the opposite way than you think they should.
