10
For something that takes so much research and can effect performance drastically, there seems to be no patents on airfoils.
Too simple in appearance to patent? They appear simple at first but the performance characteristics behind them are quite complex.
I have found patents describing 3D objects such as turbofan blades using a combination of airfoils, twist and sweep combined. There seems to be nothing showing or describing a 2D profile of a wing unless it's flaps.
    $\begingroup$ By "2D" do you mean flat wings consisting of one surface with no camber? $\endgroup$ Feb 19, 2021 at 22:02
    $\begingroup$ @nielsnielsen I’m assuming the OP means the airfoil profile. For instance the Clark Y versus an Eppler 387. $\endgroup$
    – Eric S
    Feb 20, 2021 at 1:53
4 Answers 4
14
There certainly are airfoils that are patented. Here is an example. Here is another airfoil by the famous aerodynamicist Richard Whitcomb. I think it is tricky in practice to obtain a patent in that you need to define the airfoil in a way that isn't so narrow as to be useless for protection. Just claiming a series of coordinates would provide very little protection as someone could make minor changes to avoid infringement.
  • $\begingroup$ I think this begs the question: How much of a change to the coordinates would be required to not be in violation of the patent? $\endgroup$ Feb 20, 2021 at 15:34
  • $\begingroup$ @RockPaperLz-MaskitorCasket Depends entirely on how the claims are worded. While searching I found several patents related to wind turbines but very few for aircraft. $\endgroup$
    – Eric S
    Feb 20, 2021 at 15:39
    $\begingroup$ Yes, this is part of the patent process (and enforcement) is still very much a mystery to me. I have a hunch it comes down to "it's up to the courts" (which vary from country to country), but I really don't know. $\endgroup$ Feb 20, 2021 at 17:27
    $\begingroup$ @RockPaperLz-MaskitorCasket I moderate the Ask Patents SE site so you can always ask questions there. $\endgroup$
    – Eric S
    Feb 20, 2021 at 21:39
  • $\begingroup$ Wonderful. Thanks. I have so many questions about patents that I often feel overwhelmed by the topic. $\endgroup$ Feb 20, 2021 at 22:24
10
Patenting an airfoil would be difficult- the owner of the patent would need to show that they had invented something new that wasn’t obvious, and to enforce the patent they would have to prove that somebody else’s airfoil was identical and not an improvement on the original design. Given the NACA system for describing airfoils it would be difficult to claim that an airfoil for which there was already a name was your own invention.
    $\begingroup$ Related: Submarine propeller profiles are usually not patented, but are often closely guarded secrets. They are such secrets that the props are often covered before subs are hoisted into dry docks. Sometimes they are even covered before the sub comes to the surface at any port. $\endgroup$ Feb 20, 2021 at 15:23
    $\begingroup$ I don't disagree, but there is nothing in principle that keeps someone from patenting an improvement in an existing airfoil assuming the improvement is sufficiently novel and non-obvious. $\endgroup$
    – Eric S
    Feb 20, 2021 at 15:26
    $\begingroup$ There are good reasons for not filing a patent. In particular, the patent must disclose the details of the invention, and so unless the inventor has the resources to enforce the patent they may well prefer to keep the details secret, or at least not readily available. $\endgroup$
    – Frog
    Feb 20, 2021 at 18:29
  • $\begingroup$ @Frog, which is why submarine propellers are never patented: patent enforcement against the Soviet Union would take far more resources than the US was willing to use. $\endgroup$
    – Mark
    Feb 21, 2021 at 20:26
To offer an interpretive clarification: By definition 2D and 3D imply two-dimensional and three-dimensional fluid flow. A 2D profile is, by definition, a wing section or airfoil. There are many applications for 3D flow analysis and proprietary/patented design of wings and engine turbines. For instance, understanding 3D flow would be necessary in computational fluid dynamics for innovative winglet design to lower the drag of a wing and thereby improve fuel economy, or in the specialized modification of fairings on a wing or along the fuselage to limit flow interference and thereby reduce aerodynamic drag. By definition, flaps usually means a segment along the trailing edge of a wing that can be extended, and deflected downward, to increase lift. For heavy aircraft, such flaps are slotted. The design for improved lift typically involves, in addition to the use of slotted flaps, leading-edge slats (a drooping, forward extension of the leading edge of a wing) that opens a slot to improve airflow over the upper surface of the wing and augment the improved lift from slotted flaps.
And now onward to airfoils. There are airfoils that have been patented. Many of those airfoils are designed for specialized or specific applications be they wings, propellers, or turbine blades. Patented design usually means the designer developed and applied new and original special processes, innovative procedures, or applications in the design and development of their airfoil. By originality of process and design, these are considered unique and patentable. Examples have been offered elsewhere in the answer to this question.
However, airfoil design in general may not involve this type of innovative originality, even though the designer's resulting airfoil is, in itself, highly original. The typical development of airfoils for low-speed applications uses mathematical constructs involving conformal mapping and applications in fluid mechanics. The mathematical basis for these designs originated in the early 20th century. Developments in the theory were advanced during the Second World War through a careful review of mathematical theory and verification by wind-tunnel testing. This work was done by the National Advisory Committee for Aeronautics, the predecessor of NASA. A considerable amount of this work has been published and is electronically available. Among special advances in pre-1950 airfoil design were the use of boundary-layer control to lower airfoil drag, development of advanced flap systems to improve lift, and the development of more efficient propellers.
After 1950, the specialized design of airfoils diverged. High-speed flight and the development of heavier, jet-powered aircraft, had different requirements and resulted in different advances in airfoil design. Many of these advances are considered proprietary and by their very nature, are obscure. In many cases, these proprietary features have been patented. This same element also persisted in the design of low-speed airfoils. Although the features of a design were easily recognized, understood, and attributed to known theory, backing out or reversing the process to obtain the procedure followed in developing the design would be protracted and considered largely impractical. Unless, of course, one had critical and key insights to the applied theory. Consequently, such designs have been considered the intellectual property of the designer. For all practical intents and purposes, this has been considered as good as a patent.
So if the point of a patent is to protect one's intellectual property and hopefully make money in licensing the use of that property, why would a designer simply put all that hard work out to be used for free? Actually, a lot of the design work that is not patented was not developed for free. Airfoils were specifically designed for specialized applications in aeronautics by companies providing research grants for the development of the airfoil. A general requirement is the publication of the results of the research, even though the specific procedures used in the design are not disclosed. Features that are disclosed are related to the profile itself, and its aerodynamic tests in a wind tunnel or on an actual aircraft. The resulting payment for the research, and goodwill brought to the designer through recognition of the work, is usually satisfactory.
Most airfoils are based on designs studied by the American National Advisory Committee on Aeronautics (NACA), which later became part of the National Aviation and Space Administration (NASA). The government has decided to make this data publicly available. Although Wikipedia has a wonderfully complex article on the subject, NASA.gov has much more, and much of it is readable by someone who lacks multiple PHDs.
