I was doing research on control surfaces present on an aircraft and I noticed that some aircraft like the B2 Spirit does not have a vertical tail stabilizer and therefore no rudder either.
Northrup Grumman B-2 Spirit
How do aircraft such as these perform turns and counteract adverse yaw in banked curves? Do they apply some sort of differential thrust system for turning?
13
Technically the B-2 bomber has rudders, they are "drag rudders" (or split rudder) and are located on the outer portion of the wing:
Source: Quora
The rudders open in a clamshell configuration to create a drag force on the outer part of the wing. Because these are on the outer part of the wing, they can create a significant yaw force.
