With thrust vectoring you no longer turn (as in: the wing creates the force that accelerates you in the desired direction) but you do post-stall maneuvering. Next, you need to distinguish between highest instantaneous turn rate (trading altitude for higher rate) and continuous turn rate (which is limited by the available thrust in most cases).
Turn rate diagram (picture source). It plots flight Mach number on the X axis over turn rate on the Y axis. The bold colored lines show the sustained turn performance of several airplanes. At low speed the turn rate grows in proportion to the maximum possible load factor that the maximum lift of the airplane is capable of. The kink in the lines at around 10 - 12 degree per second shows the thrust limit - in order to fly tighter turns at even higher load factors, more than the installed thrust is needed. Now the curves run almost horizontal along the thrust limit and decline again at high Mach numbers, first at the speed of sound and then when supersonic drag cuts down the possible load factor.
The thin colored lines show the instantaneous turn rate, when altitude loss is permitted. The sharp peak at the maximum load factor (for example 8g for the Su-27 and 9g for the F-15) marks the maximum turn rate when thrust is unvectored and wing lift is used to force the change of direction.
With thrust vectoring the airplane can fly a direction change in a totally different way. It will pull up to reduce speed, then rotate using vectored thrust when flying at low speed in a zero-g parabola. When the fuselage points at the desired direction, it will use the altitude gained in the pull-up to accelerate again, now in the new direction. Now the turn rate depends on how quickly the speed can be reduced and how long it takes to build up new speed. The rotation itself only needs a second or two.
Since a conventional turn also requires to slow down and missile engagement can start as soon as the fuselage points towards the adversary, post-stall turns using thrust vectoring give a decided advantage in a dogfight with missiles.
