In the past, the rules for soaring competitions in the US and many other countries have not permitted gliders (sailplanes) to have working gyroscopic instruments installed, to prevent pilots from being able to "cheat" by continuing their thermal climbs into clouds in violation of the relevant air regulations and/or the rules in place for the contest.
(The hazard of putting dozens of gliders into the same cloud is obvious, hence cloud-flying was sometimes banned by competition rules even in nations where it was permitted by the air regulations.)
As a result of these rules, in the past it was not uncommon to see a glider at a contest with blank hole in the instrument panel where the turn rate indicator had been temporarily removed.
But an ASE answer has stated
These days, AHRS is dirt cheap, and it is available on many common flight computers and varios.
Here are images of a variometer1 with an AHRS-driven artificial horizon display2--
Butterfly vario in vario mode
Butterfly variometer in variometer mode
Butterfly vario in artificial horizon mode
Butterfly variometer in attitude indicator mode
This advance in technology naturally raises the following questions--
Do the rules used in modern soaring competitions still ban dedicated gyroscopic flight instruments such as the old-style mechanical turn rate indicator and attitude indicator?
Do the rules used in modern soaring competitions forbid the use of instruments with the capability of displaying a simulated "attitude indicator" driven by means of AHRS (artificial horizon reference system)?
If an instrument with such a capability is allowed, is there a requirement that the attitude indicator display not actually be used, i.e. that that particular display screen not be selected in flight?
If so, would the selection of that screen be "flagged" in some way such that it will be known after landing-- similar to if a motorglider uses its motor during a contest task?
A close look at the website that is the source of the images included in this question reveals that in the particular case of the "Butterfly" variometer, the articial horizon display "can be deactivated in a tamper-proof manner". Is such deactivation actually required by the rules in place for soaring contests?
Basically I'm asking if, in soaring contests where the rules prohibit cloud flying, there's anything other than "the honor system" in place to prevent pilots from using a modern variometer featuring an AHRS-driven attitude indicator display to "cheat".
Are the flight tracks evaluated afterwards and compared to the forecast or reported cloud bases? That would seem to allow for at least a thousand feet or so of "cheating" due to variations in cloud base over time and space--
My question is not meant to be specific to the USA, but answers should note which nation they are describing.
Any rules that apply to record attempts, badge flights, etc rather than to actual contests would also be of interest.
I'm asking specifically about sailplane competition, not hang gliding or paragliding.
Footnotes--
  1. The primary reason that AHRS systems began to be integrated into sailplane variometers was to facilitate the use of accelerometers to provide faster detection of changes in vertical speed than would be practical with an instrument purely based on changes in atmospheric pressure.
  2. Source of images-- "Craggy Aero" website
Some other related ASE questions and answers of interest--
Can you fly a glider in a cloud on primary instruments?
In what airspace may gliders fly in clouds in the UK without an IFR flight plan and without contacting any air traffic control facility?
Other resources of related interest--
"Teaching Instrument Flying"-- Instructor Training Notes-- Dartmoor Gliding Society -- note the comment on page 1, "It is recommended that an ‘Attitude Indicator’ is not used for initial training because this leads to over reliance on a single instrument." As hard as it may seem for today's pilots to believe, there is a long history of cloud-flying in sailplanes, especially in European countries and Great Britain, relying on a turn rate indicator as the sole gyroscopic instrument. Older books such as "New Soaring Pilot" by Welch, Welch, and Irving (3rd ed 1977) discuss this practice in detail.
"Instrument Flying Training Notes"-- Dartmoor Gliding Society -- Note the comment on page 3, "The use of the AI is not included within this course."
Cloud Flying endorsement webpage from Motorglide.co.ok
  • $\begingroup$ This is a real question-- not intended to be self-answered-- although I'm an active soaring pilot, I'm not involved in competition nor have I flown w/ these newfangled gadgets... I have people I could ask, though, so a self-answer may eventually be provided if none other is forthcoming-- $\endgroup$ Feb 4, 2021 at 15:53
    $\begingroup$ @JohnK -- Based on your answer, I've made edits to the title and to the body of the question to try to clarify the intent of the question-- the point is not "hey, I've thought of this thing I'd like to do and I'm wondering if the rules allow it", but rather more along the line of "I know this has been an issue in the past and I'm wondering how the solution used in the past has been adapted to deal with recent changes in technology." $\endgroup$ Feb 4, 2021 at 20:42
As I'm not a competition sailplane pilot, I can't answer all your questions. The Soaring Society of America (SSA) sets rules for soaring competition. The newest version of the rules (2021) state:
6.6 Restricted Equipment
6.6.1 Each sailplane is prohibited from carrying any instrument that
-Permits flight without reference to the ground
-Is capable of measuring air motion or temperature at a distance greater than one wingspan
There is a supplemental document from 2012 describing possible waivers:
By waiver, the Rules Committee may allow the installation of such a device if the RC determines that the “artificial horizon” or “turn and bank” capability can be effectively and verifiably disabled for the period of the competition.
The rules and supplemental documentation can be found here: https://www.ssa.org/ContestRules
    $\begingroup$ Welcome to aviation.SE! Please use the quote markup (the quote signs in the editor) for quotes; that helps people who use screen readers, for example. $\endgroup$
    – Pondlife
    Mar 31, 2021 at 17:13
At a very basic level, VFR flight, whether it's power or glider, in any normal jurisdicton, requires cloud clearance laterally and vertically, and there's no exemption from national VFR regulations for glider competitions in any universe I know of. When soaring on a normal day, you are technically violating national VFR cloud clearance regulations just by nestling up into a cloud base at the top of a thermal.
So from a practical perspective, it's simply illegal unless you are on an IFR flight plan, in an aircraft equipped with the certified minimum equipment, which a glider with AHRS falls far short of. I don't know how a soaring organization in any Western country could authorize a deviation from basic aviation regulations like that.
Plus at a very basic airmanship level, intentionally flying around in cloud just for fun, without the specific training required to do it safely (you know, actual instrument flying training), is just crazy, and old practices doing that sort of thing in Europe or wherever in the past doesn't make it any less crazy.
  • $\begingroup$ Actually this answer would be better suited to a question more like this one-- aviation.stackexchange.com/q/26808/34686 $\endgroup$ Feb 4, 2021 at 17:54
  • $\begingroup$ Your answer also begs the potential ASE question "Is there a minimum equipment list for cloud-flying in gliders?" (Say, in the US) $\endgroup$ Feb 4, 2021 at 18:18
  • $\begingroup$ My answer responds to your 4th last para. Your question is not relevant because it relates to an activity that is illegal in the first place except as an escape from trouble. At least in North America. $\endgroup$
    Feb 4, 2021 at 18:19
    $\begingroup$ @JohnK FAR 61.3(e)(3) says it’s at least theoretically possible to fly IFR in a glider. $\endgroup$
    – StephenS
    Feb 5, 2021 at 5:05
    $\begingroup$ Under european SERA, it is possibble to fly inside clouds with gliders. In short: this requires some special training, instrumentation, and a flight plan, none of which are "full IFR" as in powered flight. This, to some extent, invalidates this answer. $\endgroup$
    – Jpe61
    Apr 1, 2021 at 5:55
