I read somewhere that sometimes gap between the wing and aileron is sealed and this is done to reduce drag. But somewhere else I read that "slotted" ailerons allows for better aileron effectiveness. So which design is beneficial? Is it possible to find an optimum solution or one design exclude other one? And second question - which type of drag unsealed ailerons generate?
1$\begingroup$ The question title had me imagine a situation which is definitely a disadvantage to sustained flight but a unique experience for the marine animal. $\endgroup$– SanchisesCommented Feb 2, 2021 at 14:31
$\begingroup$ I immediately thought, "Doesn't the weight of the seal make each aileron hard to move? And don't you need seals with identical weights on each aileron to balance them out? What if one seal dives off the aileron into the water before the other?" $\endgroup$– John KCommented Feb 2, 2021 at 16:27
This will become a long answer again.
The most important benefit of an internally sealed aileron is reduced control forces. Ailerons require lots of attention to keep forces small while still avoiding a negative force gradient (that is when the aileron runs into its stops all by itself). In most manually controlled airplanes the ailerons become stiff as a brick at high speed and the designers of airplanes like the P-47 and the Do-335 even used telescopic sticks which would give the pilot a longer lever arm at high speed, albeit at the price of a smaller deflection range. But the larger deflections were impossible to steer anyway …
Only when much care is put into aileron design will control forces be manageable at high speed. Examples are the Supermarine Spitfire or the Junkers Ju-88. To be able to control the plane with only two fingers on the yoke at 500 km/h required several hours of flight testing and adjustable aileron hinges in case of the Ju-88. Another fine design is the English Electric Canberra (known as the Martin B-57 to you Yanks) which had a spring between stick and ailerons. The pilot would only move one side of the spring while the other would move the control rod running to the ailerons. On the ground, you could move the yoke easily ±60° while someone else would keep the aileron from moving - that is how soft that spring was. Now you have a moving mass and a spring - what comes to mind? Flutter! This was a very risky design and it shows how desperate the engineers were to get the aileron forces down. And of course those ailerons were sealed. With an internal seal.
You can either use a brush seal or a cloth seal, but in all cases you need something protruding forward of the hinge line into a cavity inside the rear wing. This restriction will keep maximum deflections down to less than ±20° but will produce the best aerodynamic balance. In case of the Canberra, the chord of this forward plate was almost 40% of the aileron chord, measured from hinge to trailing edge. This is what it takes to compensate >90% of the aerodynamic force. The F-86 Sabre ailerons were similar and used a cloth seal while the Canberra used a brush seal (IIRC). The downside is the maintenance and care to keep the cavity clean. Especially water trapped there which freezes as the airplane climbs into colder air can produce unpleasant surprises.
If you only fly slowly, an external seal is also possible. This is popular on gliders where sometimes the hinge line is placed as closely as possible to the lower skin in order to seal the aileron gap with a sticky tape. More elaborate seals use a thin metal ribbon like in the picture below on a PA-28. The main benefit is a higher aileron effectiveness and a very slight drag reduction. The downside is a bit more friction and more care to keep the seal in shape.
Exernal seal (picture source). I would have preferred to show that of the ASW-20C here, but could not find a decent picture online. The ASW-20C tries to extend the laminar run on the lower side across the flap and aileron hinge line with its seal.
External seals only improve the aerodynamics and aileron effectiveness, but don't help with the stick forces. Since only one side can be the one with the hinge, the opposite side still has a gap.
So why would you prefer to have a vented aileron? First, this allows for higher deflection angles. Second, now the aileron nose can be shaped such that it helps to tailor the stick forces. Case in point: The Frise aileron.
Frise aileron (picture source)
At very small deflection angles the nose of the aileron stays within the airfoil contour. This allows for a stiff centering of the ailerons, so you can feel when the ailerons are neutral. Note that a Frise aileron should be combined with aileron trim! When the deflection increases, the nose of the trailing-edge-up aileron will poke out of the contour and produce a suction peak which forces the aileron to an increased deflection. This force now is transmitted via the linkage to the opposite aileron and helps to force it trailing-edge down. This means at moderate deflection the stick forces become pleasantly low. Once the aileron deflection is too high for the flow to stay attached to the aileron's suction side, the pressure distribution over the aileron changes, the forces increase rapidly and the stick forces tell the pilot that he has reached the limit of the useable range. At high speed this helps to prevent overstressing the wing while at low speed the aileron can be deflected further, maximizing its effectiveness. The picture above mentions drag - this helps to reduce adverse yaw a bit, but the main reason for a Frise-type aileron should be lower mid-range stick forces.
Why else would a vented aileron be preferable? The gap reduces aileron effectiveness but keeps the flow attached at higher deflections. This gives more control authority at the price of increased drag. But there can be more: A clever way to install vortex generators can be found on the Short Belfast:
Tail of the Short Belfast from below (own work). Note the vortex generators hidden in the hinge gap - they only move out into the airflow when they are needed: When the elevator is moved to large negative deflections. This is not an aileron, admittedly, but the same can be done at the aileron, too.
To summarize:
Pros of internal seals:
- much lower control forces at high speed
- good aileron effectivity
Cons of internal seals:
- limited deflection range
- have to be kept clean all the time
Pros of external seals:
- No gap on one side, lower drag
Cons of external seals:
- a bit more friction
- care is needed when handling the delicate seals
Pros of vented ailerons
- allow to tailor stick forces and reduce adverse yaw
- higher deflection angles possible, especially at low speed
Cons of vented ailerons
- more drag
- lower effectivesss
The key factor is the airflow through the gap in front of the aileron itself. This gap increases the maximum lift coefficient (and thus effectiveness) of the aileron by introducing high-energy airflow from the pressure side to the suction side of the wing, thereby delaying separation. Without the gap, the adverse pressure gradient on the suction side would be too great and the flow would slow down and separate from the aileron.
This is the idea behind F1 cars having multi-element (up to 6) front wings to maximize the lift coefficient and thus lift of a relatively small wing.
OTOH, the flow through the gap introduces parasitic losses by changing the direction on the suction side airflow, while also increasing the thickness of the boundary layer.
In the end, the tradeoff is between a smaller and lighter aileron and lower parasitic drag. For a STOL aircraft design, weight is paramount, so it pays to lose a few knots of cruise airspeed to have smaller and/or more effective ailerons, which could also work as flaps (flaperons). On a sleek twin-prop aircraft, however, speed is a major selling point, adding a few tens of kilos to the aircraft and lengthening the takeoff ground roll by a few tens of metres is not a big deal compared to outright speed and fuel efficiency.
2$\begingroup$ You'll actually see airplanes with "speed kits" that have the gap seals added to cover the slot to stop the leakage for the drag reduction. Overall, the slot isn't worth it unless you don't want to go very fast. $\endgroup$– John KCommented Feb 2, 2021 at 20:28
