See this article: Aerodynamic Performance Improvements Due to Porosity in Wings at Moderate Re
Was wing porosity ever tested/used for real aircraft?
source:
The aerodynamic efficiency parameter clearly shows the positive effect of the permeability for low angles of attack. Having a permeable section on the airfoil surface will provide better aerodynamic characteristics when the angle of attack is less than 10°. This is compatible and in agreement with the observation of other researchers on the effect of the holes on the aerodynamics characteristics of the airfoil that concluded that “at a transitional phase where Re= 40,000 and the angle of attack ranged from 0 to 9°, the L/D ratio was higher compared to the same wing without holes
  • $\begingroup$ Paraglide wings are permeable to varying extents but porosity is generally considered to be a bad thing as it is believed to increase the likelihood of a parachutal stall. $\endgroup$
    – Frog
    Feb 27, 2021 at 9:02
Not really a great answer but: Tested - yes I believe so. Actively used - not to my knowledge/unsure. The structural complexity of this is challenging, and the cost to benefit probably isn't compelling enough for "traditional" configuration aircraft.
You may find this of interest A History of Suction-Type Laminar-Flow Control with Emphasis on Flight Research or Aerodynamics of Permeable Membrane Wings
First, analyzing the data shows some lift and drag benefits at low AOA but much worse performance at higher AOA. Why?
Because with undercambered wings, at higher AOA the concave bottom creates a higher pressure lifting "bubble" which a "permeable" area hurts. At lower AOA, a little "bleed" through the wing may enhance lift and reduce drag by delaying boundary layer separation on the upper wing surface. Slotted ailerons and flaps are known to be highly effective in full scale aircraft for the same reason.
Using the Reynolds formula to check 40,000
Re = Chord x Velocity/1.46 x 10$^-5$ m$^2$/s
we see chord and velocity to be on the order of a small bird. Highly cambered wings such as these have a very limited speed range and area rarely seen on full scale aircraft (Reynolds number around 2 million and up), which utilize slats and flaps (similar) for lower speed flight. These are retracted for cruising to reduce drag.
As a final thought, looking at modern airliner wing design, an alternative to permeable trailing edges is to have no wing there at all. This is what is achieved with higher strength composite building materials: higher aspect ratio.
