All aircraft that operate at night or in poor weather need position lights to make them visible to other aircraft for the purpose of avoiding mid-air collisions. On most aircraft, these follow a set pattern: two continuously-illuminated lights on the wingtips (red on the left wingtip, green on the right [a pattern inherited from marine navigation lights], to allow other aircraft to see whether yours is flying towards or away from them), a continuously-illuminated white light in the tail, and high-intensity white anticollision strobe lights on each wingtip, in the tail, and on the upper and lower surfaces of the fuselage.
However, according to the Wikipedia article on the Ilyushin Il-62, early Soviet jetliners did not follow the standard arrangement for position lighting:
The Il-62 entered Aeroflot civilian service on 15 September 1967 with an inaugural passenger flight from Moscow to Montreal, and remained the standard long-range airliner for the Soviet Union (and later, Russia) for several decades. It was the first Soviet pressurised aircraft with non-circular cross-section fuselage and ergonomic passenger doors, and the first Soviet jet with six-abreast seating (the turboprop Tu-114 shared this arrangement) and international-standard position lights. [Emphasis added.]
What arrangement of position lighting did pre-Il-62 Soviet jetliners use?
