As even minuscule amounts of ice accumulation on aircraft can cause tremendous loss of lift, increases in drag, decreases in engine thrust, and/or flight-control impairment, some method of detecting ice is essential for safe flight, even for aircraft not certified for flight into icing conditions. Various methods exist for doing this, ranging from examination with the Mk. I eyeball (for many light general-aviation craft, and even some larger planes) to sophisticated electromechanical systems utilising vibrating probes which change frequency when made more massive by ice accumulation and set off an alarm in the cockpit.
For aircraft not certified or equipped for flight in icing conditions, the detection of ice lets the flightcrew know that they need to get out of the ice ASAP. For aircraft which can fly in ice, it signals the need to activate the aircraft’s built-in deice/anti-ice systems; these come in three main varieties (melting the ice using hot engine bleed air, melting it with resistance heating from electrical heating elements, and mechanically breaking it off with pneumatically-operated deicing boots), but all of these still need to be manually turned on by the pilots, even for aircraft that can automatically detect icing.
Given the potentially-catastrophic consequences of allowing ice to accumulate unchecked on an airframe, and the ease with which a flightcrew (especially if fatigued or already task-saturated) could overlook or forget about an ice warning, why don’t aircraft with automatic ice detectors and built-in anti-icing link the two together, and have the ice detector automatically turn on the anti-ice system when it detects icing?
