I was reading a discussion in flight simulator forum and I found this statement:
Ignoring the issue of engine overheating, max MAP and max RPM is the best thing for max speed
Do you agree with that? Assuming a Constant Speed Propeller.
Sign up to join this communityI was reading a discussion in flight simulator forum and I found this statement:
For maximum speed, you need maximum power from your engine. This means running it at its maximum rated RPM with the throttle wide open, and maximum manifold boost pressure for a supercharged engine. The prop governor will then adjust the prop pitch to put the biggest possible load on the engine at that RPM.
