Can you explain with example how can I calculate magnitude and direction of resultant force from pressure distribution over airfoil?
I don't know exactly you maths background, so i'll start using it for the sake of expressing it generally, and in the second part i'll try to simplify things.
Making use of the definition of pressure p as force F per Area A.
Mathematically, the shortest answer would be to integrate the (local) pressure over the surface, including the normal vector:
$\vec F = \int_{A} p* \vec n dA$
some notes on the symbols: pressure p is not directional, it is defined as pressing perpendicularly on the surface. Using $\vec n dA$ as "directionalized" surface area element, the normal vector $\vec n$ perpendicular to the surface would take care of the direction of in which the pressure is exercised. Note that the normal vector is "normalized" to the length of 1, so to preserve the pressure.
F as resulting force has a direction, making it a vector.
In real life (as in your diagrams) the distributions usually aren't known analytically, but just as a table of values. So you would discretize the above surface integral into segments of finite area, and then calculate the forces for each element, and at the end sum everyting up.
So I tried running a basic example: airfoil discretized in 5 segments (i through v), suction side pressure = 1bar (abs), pressure side 2 bar(abs),
ran the calculation "p * n * deltaA " and the summation in the Table below. The force units are "kPond" = 10 N, as result of choosing pressures in bar and surface area in cm^2.
Discretized Airfoil Calculation Table
Interpretation of the Result: We get a aero force of
10N in positive x direction: 10N of Drag, and 50N in positive y direction: 50N of Lift.
Total aero Force is 50.99N in the direction of the vector [1,5]
Additional notes: If you want to get more precise: the finer the discretization, the more precise your result will be, or you can increase the order of your numerical integration.. https://en.wikipedia.org/wiki/Numerical_integration
hope that helps! have fun integrating..
