LAANC grid for KGFL
Above is a screenshot1 from the LAANC map for obtaining authorization to operate sUAS (model airplanes, "drones", etc), centered on KGFL, which is Floyd Bennett airport near Glens Falls NY. Why does the permitted ceiling drop to zero AGL southeast of KGFL? Even though the permitted ceiling is as high as 400' AGL between this area and the airport? This configuration is very unusual.
sectional chart for KGFL
Above is a screenshot of the sectional chart for this area. The airspace in question is E2 Class-E-to-surface airspace.
Would aircraft likely be operating under Instrument Flight Rules in IMC at very low altitudes (well below 400' AGL) in the airspace SE of KGFL? Are there aspects of the instrument approaches into or out of KGFL that would justify banning all sUAS operation in the airspace 5 to 10 miles southeast of KGFL, even though there are many other airports with similar long arms of E2 Class-E-to-surface airspace where the permitted ceiling is all the way up at the maximum value of 400' AGL?
Are there any other similar cases in US airspace where as one travels in a straight line away from an airport, remaining within E2 Class-E-to-surface airspace which encompasses only a single airport with associated instrument approaches, the permitted ceiling indicated by the LAANC system increases, and then decreases again?
It's probably safe to assume that the zero-ceiling designation is not to protect the small airport "Argyle" (1C3).
sectional chart for KGFL-- zoomed out
LAANC grid for KGFL-- zoomed out
After all, in the above zoomed-out screenshot of the sectional chart from this area, we can count 33 other airports, none of which are protected by LAANC grid squares.
The following screenshots of the airspace around KSHR shows the FAA's more typical treatment of E2 Class-E-to-surface airspace: the areas distant from the airport have a 400-foot ceiling on the LAANC grid.
LAANC grid for KSHR
LAANC grid for KSHR - north end
LAANC grid for KSHR - south end
Here's a screenshot of the sectional chart showing KSHR:
sectonal chart for KSHR
Below are screenshots of the sectional chart and LAANC grid for another airport -- KTHV -- that has three outlying airports within the E2 Class-E-to-surface airspace. Note that the permitted ceiling is 400' AGL in the vicinity of these outlying airports. Reinforcing the point that the zero-ceiling grid squares southeast of KGFL are unlikely to be designated for the purpose of the protecting the airspace of the small airport "Argyle" (1C3).
sectional chart for KTHV
LAANC grid for KTHV
So what is the reason for the unusually large area of zero-permitted ceiling on the LAANC grid SE of Glens Falls airport?
Footnotes:
  1. All LAANC screenshots taken 12-23-20, and still were current as of 2-3-21.
    $\begingroup$ I’m voting to close this question because it is about Drones (belongs on Drones.SE) and not about aviation per se. $\endgroup$
    – Ralph J
    Dec 24, 2020 at 19:16
    $\begingroup$ This question looks perfectly fine to me. It would also be on topic on Drones.SE. Either one would be fine I think. I look forward to reading the answers. $\endgroup$
    – dalearn
    Dec 24, 2020 at 22:31
    $\begingroup$ This question should be re-opened. Here's why -- aviation.meta.stackexchange.com/q/4155/34686 .Consider voting to re-open. $\endgroup$ Dec 30, 2020 at 21:12
    $\begingroup$ @RalphJ and nobody posted a good reason why not. sure, not enough time has passed, but posting on meta is exactly the way it can work. $\endgroup$
    – Federico
    Dec 31, 2020 at 7:21
    $\begingroup$ This seems like a general aviation question to me - it is unlikely FAA made these changes in consultation with drone enthusiasts, so it is likely to be for reasons of general aviation. $\endgroup$
    – Rory Alsop
    Dec 31, 2020 at 15:13
It turns out that the E2 Class-E-to-surface airspace around KGFL has been recently expanded, and the long "arm" projecting to the southwest is a new addition. KGFL is listed in the current (as of February 2021) version of the FAA's "Airspace Designations and Reporting Points" document, FAA Joint Order 7400.11E. The airspace change was published in the Federal Register on July 31, 2020, and became effective November 5, 2020. The old airspace description may be seen on page E-30 of the July 21, 2020 edition of the Airspace Designations and Reporting Points document, J.O. 7400.11E.
One might wonder whether, after the airspace change, the newly-added LAANC grid squares were assigned a zero ceiling to accommodate some unusual feature of the new instrument approaches and departures in the vicinity, while by some oversight no adjustment was made to adjust the ceilings of the previously existing grid squares to accommodate the new approaches and departures.
Close scrutiny of the approach plates suggests that this is unlikely. Granted, there is some modest amount of relief in the terrain southeast of KGFL. The ridge east of the town of "North Argyle", about 9.6 miles from the airport, tops out at just over 1000' MSL-- let's call it 1100' MSL to be conservative. The airport KGFL is at 328' MSL, so by our conservative estimate the top of the ridge is 772' higher than the airport. This works out to a slope of 66 to 1, or 0.87 degrees above horizontal. Add 400' to the top of the ridge to represent the maximum AGL altitude that the FAA typically grants for sUAS operations, and we have a 43.4 to 1 slope to the airport, or 1.32 degrees above horizontal. It is difficult to see how permitting sUAS flight beneath this less-than-2-degree-slope would endanger aircraft on the instrument approaches into KGFL. For example, the RNAV (GPS) RWY 30 approach appears to show a Final Approach Fix ERUPE at 2300' MSL just 5 nautical miles from the airport. The Intermediate Fix CATIR is at 4200' MSL, 12 nautical miles from the airport.
Further scrutiny has revealed that the zero ceiling assigned to the new LAANC grid squares southeast of KGFL perfectly fits a pattern, that appears to have little relationship to safety considerations.
The pattern is as follows: for most or all expansions or other modifications of existing controlled airspace effective 9/10/20 or later, any new squares that have to be added to the LAANC grid have been assigned a ceiling of 0 AGL.
As a result, whenever a significant new "arm" or projection is added to an existing area of controlled airspace, then we can get a pattern like we see at KGFL, where the portion of the new projection that lies outside of any previously existing LAANC grid squares is assigned a ceiling of zero, while the (older) grid squares closer to the airport retain a higher ceiling.
On the other hand, when an existing area of controlled airspace is expanded by a small amount, then we can have a pattern where just a few new LAANC grid squares, seemingly randomly scattered around the periphery of the old airspace, need to be created to accommodate the expanded airspace. Very often the new airspace just barely impinges into most of these new grid squares. All of these new grid squares are assigned a ceiling of zero. This can happen even when the airspace is not actually expanded at all, but rather is simply moved a few hundred feet due to a slight change in the official location of the airport. It's pretty clear that no safety consideration could possibly be involved in the zero-ceiling assignment in the latter case.
Why this pattern has recently arisen, remains a mystery. At present it would be hard to say whether it is due to a decision taken at a high level of the FAA, or due to the choices of some particular data entry technician, or due to exigencies of life in the time of Covid-19. Is there an intention to revisit these cases and correct the arbitrarily low ceiling assignments? Is there an intention to continue the practice indefinitely? The FAA sUAS Help Desk has been contacted, and further developments may ensue.
Here are additional specific examples of the pattern described above:1
KDRO -- Durango-La Plata County Airport -- Durango CO -- E2 Class-E-to-surface
Old airspace description page E-72 in FAA Joint Order 7400.11A,new airspace description on page E-68 in Joint Order 7400.11E. Effective 09/10/20, the official airport location was moved about 130' to the NW, but more significantly, a new "arm" was added to the Class E airspace, projecting 2 miles to the NE, 2 miles in width. As a result of this new "arm", 7 new squares were added to the LAANC grid, of all which assigned a ceiling of zero. Note the presence of grid squares with a 400' ceiling between the new zero-ceiling grid squares and the airport.
KDLN -- Dillon Airport -- Dillon MT -- E2 Class-E-to-surface -- second attachment
Old airspace description page E-77 in 7400.11A, new airspace description page E-74 in 7400.11E. Effective 9/10/20, the Class E circle was decreased in radius by 0.9 miles, but a new "arm" was also added, 4.8 miles in width and projecting .7 miles beyond the original radius. As a result of this new "arm", 8 new squares were added to the LAANC grid, all of which were assigned a ceiling of zero. Again, note the presence of grid squares with a 400' ceiling between the new zero-ceiling grid squares and the airport.
KCXO -- Conroe-North Houston Regional Airport -- Houston, TX -- Class D --third attachment
Old airspace description page D-125 in 7400.11A, new airspace description page D-125 in 7400.11E. Effective 9/10/20, the official location of the airport was shifted about 350' to the NNW, and the radius of the Class D circle was increased by .7 miles (about 3700'). As a result of these changes, 27 new squares were added to the LAANC grid, all of which were assigned a ceiling of zero. Again, note the presence of grid squares with a 400' ceiling between the new zero-ceiling grid squares and the airport.
KFWS -- Fort Worth Spinks Airport -- Fort Worth, Texas -- Class D --fourth attachment
Old airspace description page D-129 in 7400.11A, new airspace description page D-125 in 7400.11E. Effective 9/10/20, the official location of the airport was shifted about 85 feet to the west. As a result of these changes, a single new square was added to the LAANC grid, barely penetrated by the new location of the controlled airspace, with an assigned ceiling of "0" AGL. Again, note the presence of grid squares with a 400' ceiling between the new zero-ceiling grid square and the airport.
KALN -- St Louis Regional Airport --Alton/St Louis, IL -- Class D
Old airspace description is on page D-31 in 7400.11E, new airspace description is on this page of the Federal Register. page D-125 in 7400.11E. Effective 11/05/20, the Class D airspace was expanded by .2 miles (about 1056 feet), and the center of the circle was shifted about 218' to the southwest due to the change in the official location of the airport. As a result, there are now 6 anomalous zero-ceiling LAANC grid squares running from the south edge of the airspace clockwise around to the northwest edge of the airspace. Note the presence of grid squares with a 400' ceiling between the new zero-ceiling grid squares and the airport.
PABE -- Bethel Airport-- Bethel, AK-- Class D
Old airspace description is on page D-3 in 7400.11E, new airspace description is on this page of the Federal Register. page D-125 in 7400.11E. Effective 12/31/20, the Class D circle was shifted about 430' to the southeast due to the change in the official location of the airport. As a result, there are now 3 anomalous zero-ceiling LAANC grid squares at the southeast edge of the airspace. Note the presence of grid squares with a 400' ceiling between the new zero-ceiling grid squares and the airport.
PASI2 -- Sitka Rocky Gutierrez Airport -- Sitka, AK -- E2 Class-E-to-surface airspace
Old airspace description is on page E-9 in 7400.11E, new airspace description is on this page of the Federal Register. Effective 11/05/20, the Class-E-to-surface circle was shifted about 150' to the southeast due to the change in the official location of the airport. As a result, there is now a single anomalous zero-ceiling LAANC grid squares at the ESE edge of the airspace. Note the presence of grid squares with a 400' ceiling between the new zero-ceiling grid squares and the airport.
Footnotes:
  1. All LAANC screenshots taken on 2-1-21
  2. As of 2-1-21 this link to an on-line portrayal of the aviation sectional chart covering PASI still showed the airspace as it was configured before a recent change that came into effect 11-5-20. It appears that the 11/5/20 edition of the Juneau sectional chart has not yet actually been made available on-line (see non-working links for Juneau sectional on the FAA's "VFR Raster Charts" page.) The new configuration of the airspace at PASI, which involves a (nearly circular) E2 Class-E-to-surface area and a single, very large, rectangular E4 Class-E-to-surface extension, may be seen by selecting the appropriate layers on the LAANC map display after entering "PASI" into the search window. The airspace configuration at PASI therefore is now similar to the airspace configuration at KACV and KTLV, as described in the related ASE question What is the primary reason that the non-towered airports KACV and KTVL have E4 extensions to E2 airspace? .
  • $\begingroup$ Hopefully the FAA answer sheds more light on this! $\endgroup$ Feb 3, 2021 at 3:21
  • $\begingroup$ @UnrecognizedFallingObject -- the particular case of KGFL has now been fixed-- LAANC now shows a 400' ceiling for the grid squares in the arm of controlled airspace projecting off to the southeast. The other cases haven't been changed yet. At some point I'll update the answer. $\endgroup$ Feb 24, 2021 at 17:02
