Some times we see images of jet engines on the net that have strange colors. For example take a look at the bellow image. What the operator is doing? Why the color of blades are white with red on its borders? why are they numbered? why is the color of spinner yellow?
Source of image
This is most likely some kind of a test where high speed photography (as in 5,000 - 10,000 frames/second) will be used to capture the detailed motion of the fan blades.
Types of tests that might require this type of video include fan blade out testing, bird strike testing, and icing / hail testing. There may be others but those are the most common.
In order to get 10,000 frames per second you need a lot of light. There will be many high powered lights shining on the engine. You don't want harsh reflections from the lights, so you need a matte finish, the flatter the better. The normal blade finish is way too shiny. So they are painted.
just for contrast, so you can very clearly tell in video where the blade stops and the fan case starts. The exact color is arbitrary, and different OEMs have different traditions. You are just looking for a set of colors are very different from one another.
So in the high speed video, you can see what happens to what blade. For example, in a hail test, you might observe that a giant chunk of hail hit blade #15. You could then go inspect blade #15 afterwards and see if there is any damage.
Same as the red border. Just for contrast, so you can see where the blades stop and the spinner starts.
I don't know exactly. Obviously some kind of assembly or disassembly procedure. You can tell in that photo that the inlet is not attached, he's right up against the plane of the fan blades. So it's not a fully assembled engine on the airplane or on a test stand. It's clearly in the factory somewhere. But what exactly he's doing I don't know. Honestly could just have been "hey we need some publicity photos for Aviation Week, pretend to do something interesting with the engine".
  • $\begingroup$ White & red combo is good, as it has high contrast in color, greyscale and black and white formats. $\endgroup$ – Jpe61 Dec 22 '20 at 11:11
The blades may be part of a test fixture. The uncropped image is from a 2018 report in the Telegraph, which includes another photo captioned
Rolls-Royce's new Pearl engine for private jets undergoes tests
Credit: Rolls-Royce
  • $\begingroup$ Labeling blades for tests is very common, even for those run at full throttle. If the label is for example drawn on the blade with a marker using a stencil, the added weight will be insignificant. For example see youtu.be/736O4Hz4Nk4 1:24 onwards. $\endgroup$ – Jpe61 Dec 20 '20 at 22:49
