There is a small air intake on the root of the tail of some aircraft, especially those with engines near the end of the aircraft. What is it and why is it located there? enter image description here
  • $\begingroup$ If you put your hand next to one of the rectangular exhaust louvers below and behind the engines, you will find the air coming out is quite hot. Those are the exhaust end of the inlet on the fin. The heat is what was extracted from the bleed air that was going though the AC packs. $\endgroup$
    Dec 12, 2020 at 15:01
That is the Ram Air Inlet for the air conditioning system:
Ram air, taken from the air scoop in the base of the vertical fin, is used as the cooling medium for the heat exchangers. Ram air passes across the precooler and the dual heat exchangers, extracting heat from the bleed air used by the air-conditioning packs. The ram air is discharged through exhaust louvers on the upper left and right sides of the aft fuselage.
Air Conditioning System
During unpressurized flight, ram air may be used to ventilate the cockpit and cabin.
(Bombardier Challenger 605 - Air Conditioning & Pressurization)
The reason why it is located there is obvious from the picture above: the two air conditioning units (ACUs) are located just below so this provides the shortest duct. For tail mounted engines, this is the optimal location for the ACUs (also called PACKs) because the bleed air ducts from the engines (or APU) can be short this way. The ram air can also be used for ventilation when the pressurization has failed.
For wing mounted engines, the PACKs are usually located in the belly. The inlets are then found on the underside of the aircraft:
What exactly are those openings in the bellies of many jetliners?
On some turboprops you can also find them on the side:
What's this hole on the ATR-72?
    $\begingroup$ You should mention that the same inlet does double duty. It is also the source of ram air flow for emergency cabin ventilation when flying depressurized. $\endgroup$
    Dec 12, 2020 at 15:04
  • $\begingroup$ @JohnK Good point, added. $\endgroup$
    – Bianfable
    Dec 12, 2020 at 15:06
