31
Describing lift as the result of "equal transit time" on both sides of an airfoil is a fallacious theory widely found in technical books and articles for general public (see below for details about this explanation).
But such explanation is also found in aviation books, in spite being identified by NASA as an incorrect theory (NASA explains that if lift is computed from fluid laws, based on airspeed on both sides of the airfoil, the result will not be in line with what is observed in real life).
Question
Is this very popular theory also taught this way in flight schools? (please note the question is about pilot teaching, not about what is lift.)
Annex: Popular explanation of lift from equal transit time:
Supporters of this theory explain aerodynamic lift results from the differential of pressure between lower and upper sides of a wing created by Bernoulli principle. They say:
  • Air has to move a longer distance on the upper side because of the curve of the profile (not correct for all wing profiles).
  • Both sides must be traveled in an equal amount of time so that air molecules that were nearby ahead of the wing, will meet again behind it (may be right or wrong.)
  • By Bernoulli's principle accelerated airflow has lower pressure. Pressure is then lower on top of the wing, and higher on bottom. Hence the wing receives a force which has a vertical component upward. This component balances the weight of the aircraft, and allows to stay aloft.
    $\begingroup$ this is well discussed over on the physics.SE: physics.stackexchange.com/questions/290/… $\endgroup$ Aug 21, 2014 at 19:19
    $\begingroup$ The See How It Flies explains physics relevant for flying aircraft, including lift and it is targeted specifically at aviators. $\endgroup$
    Aug 21, 2014 at 21:18
  • 11
    $\begingroup$ The "Bernoulli vs Newton" is the biggest nonsense. The actual answer is "Bernoulli and Newton" and it's actually Newton's first law (inertia of the stream is needed get stall in the picture). $\endgroup$
    Aug 22, 2014 at 7:48
    $\begingroup$ Newton's law explains why pushing the air down pushes the aircraft up. It doesn't explain why the air gets pushed down in the first place. $\endgroup$
    – user253751
    Apr 2, 2015 at 6:27
    $\begingroup$ Conversely, Bernoulli's law explains why the air goes down, but not why the aircraft goes up. $\endgroup$
    – user253751
    Apr 2, 2015 at 6:28
4 Answers 4
22
I am a CFI who teaches at a large (+200 students) flight school in the United States. You might be surprised to hear this, but...
We really don't worry about how a wing works that much.
As far as I'm concerned, the technical explanation for how a wing works is a subject for the engineers who build and design such things. Private pilot applicants (at least all of the ones that I have met) are more concerned with things like "How do I get the plane into the air??" and "What do I do if it starts coming back down again in a hurry?"
In fact, Van Sickle's Modern Airmanship starts off the chapter on aerodynamics by saying (paraphrased):
Some of the concepts presented in this chapter are wrong, but they are useful illustrations.
So, to answer your question, we teach that:
  1. The alignment of the wing to the relative wind displaces air downward, which creates lift.
  2. Because of the shape of the airfoil, air on top of the wing has a lower pressure than air below the wing, which also causes lift.
And unless a student asks us for more information, we leave it at that.
If you hope to become an aircraft designer or research fluid dynamics, you'll quickly be corrected of any misconceptions you may have about Mr. Bernoulli and his asymmetric wing. Most student pilots, however, are satisfied with a pre-discussion "What we'll talk about today isn't technically correct, but you'll find it a lot easier to understand the necessary concepts this way."
Peter Kämpf made a worthwhile comment:
It is really not so hard to understand aerodynamics correctly, and you make it sound as if you prefer a short term gain over a profound basis which could help pilots to really understand what happens with their plane and to select the most appropriate action.
Which is very true - it's not difficult to understand aerodynamics correctly. I'll defend my viewpoint with an analogy: Consider a store where you are shopping with a child who doesn't yet understand decimal addition. You have two purchases, one costing $5.08 and one costing $3.99. The child adds the big numbers and tells you that the final price will be $8. You now have (at least) two choices: you could begin a discussion of significant figures and fractional multiplication (can't forget tax!), or you could praise the child for applying the skills they do have and getting an answer which is pretty close.
Is it better if the child eventually understands how to calculate tax rather than simply trusting what the cashier reads off the screen? Of course. But at the stage where most of my students are, it's much more valuable to their development as pilots to simply praise them for being close enough.
As regards JAL123, I am in 100% agreement with you. By the time you as a pilot have progressed sufficiently in your development to be flying something with a turbine pushing it, you should certainly know the principles and concepts of your machine to the highest degree of accuracy.
    $\begingroup$ It is really not so hard to understand aerodynamics correctly, and you make it sound as if you prefer a short term gain over a profound basis which could help pilots to really understand what happens with their plane and to select the most appropriate action. $\endgroup$ Aug 22, 2014 at 6:58
    $\begingroup$ @PeterKämpf: It depends on which level of understanding you need. For pilot it's enough to know that the lift is proportional to square of indicated speed and angle of attack until some point where it decreases abruptly because stall happens. The common explanations don't help that, because they don't explain stall; I'd say just showing pictures of the streamlines should be enough. $\endgroup$
    Aug 22, 2014 at 7:41
    $\begingroup$ @PeterKämpf that B52 still have aileron+elevator control; while JAL123 didn't (only engine diff-thrust) $\endgroup$ Aug 22, 2014 at 12:01
    $\begingroup$ @Farhan - Those are the intended link targets. "What makes an airplane fly? Money." is a well known joke among aviators in the USA, and "Unload for control" is a method of upset recovery. $\endgroup$
    – Steve V.
    Aug 22, 2014 at 14:09
    $\begingroup$ @SteveV. Got it. I heard about the money relation with airplane flying but wasn't too sure if many pilots are .NET programmers in their free time. $\endgroup$
    – Farhan
    Aug 22, 2014 at 14:27
10
I can only speak on behalf of the Australian Syllabus as put out by CASA (Civil Aviation Safety Authority - Australia), but we are expected to teach both Bernoulli's Theorem, and the Theorem of Air Deflection (I believe this is the second theory you are talking about in regards to Newton's Laws).
BUT, we are also expected to teach these items as theories, not laws, as there is no law on the creation of lift. So to a degree, you could say we do teach misconceptions, but also at the same time we openly acknowledge those misconceptions to those we are teaching.
The other part we openly admit is that both theories have merit to at least help understand certain important characteristics of Aerodynamics in-flight, great example is a stall. We have the Centre of Pressure that moves further forward along the Wing Chord as the Angle of Attack is increased, due to the "peak" of dynamic air pressure being more forward along the wing chord. At the "Critical Angle" in is at its most forward position. As soon as we exceed the Critical Angle, the wing is stalled and instantaneously, the Centre of Pressure moves aft along the chord line to a position approximately half way along the chord due to Bernoulli's theorem no longer having the principle effect on our wing. Now the theorem of air deflection takes over, and we look at using the "hand out the window of a moving car" analogy.
    $\begingroup$ Could you make it clearer what you're referring to when you say Bernoulli's Theorem and teach these items as theories, not laws? Bernoulli's Principle (an increase in fluid speed means a decrease in fluid pressure) simply describes a physical reality; it's not really a theory. $\endgroup$
    – Steve V.
    Aug 22, 2014 at 3:41
    $\begingroup$ @SteveV. - The theorem is how this applies to an aircraft Aerofoil, as there is not a physical venturie. The principle is solid, and at no stage in doubt, but how this applies to a wing, and the overall production of Lift is still only a Theorem. As for your answer below, this may be the case with the FAA syllabus, but other countries, such as Australia, it is a requirement that all PPL applicants have a basic understanding of how Lift is generated, and for CPL applicants, there must be a good understanding of how Lift is generated (at least the Theorems associated). $\endgroup$
    – James Ham
    Aug 22, 2014 at 5:07
  • 20
    $\begingroup$ You seem to misunderstand what a theorem is (it's a proven result of mathematics) and what a scientific theory is (it's an experimentally verified explanation of how the world works). A scientific "law" is just a scientific theory that is so old and famous that it has a fancier name. To say "we teach these as theories not laws" is a huge misunderstanding of what science is. $\endgroup$ Aug 22, 2014 at 7:13
  • $\begingroup$ And a "law" doesn't even mean it's more complete or accurate than a "theory." Consider the law of gravity, which has been superseded by the theory of relativity. $\endgroup$
    – yshavit
    Oct 7, 2015 at 15:41
  • $\begingroup$ By "Bernoulli's Theorem", do you mean equal transit time or something else (because Bernoulli's theorem obviously holds around the wing; it just leaves too many free variables and fixing them by assuming equal transit time is the error)? And by "Theorem of Air Deflection" do you mean the reflecting bullets or something else (because air is deflected downwards; it is just the idea that it is because the particles hit the underside and reflect like balls bouncing off a wall that is wrong)? If you mean these, how do you explain stall? If you don't, please clarify what you mean. $\endgroup$
    Feb 6, 2017 at 18:37
I would like to add my $.02 to this question. Lift is defined (in the aerodynamic texts) as the upward component of the force that the air exerts on the wing. The force is composed of the tangential (sheer) forces that tend to contribute mostly to drag, as well as the pressure (normal) forces that tend to contribute to lift. As for designing the most efficient wing, the answer is trial and error. Hundreds of different mathematically-defined airfoils are put into a wind tunnel and their lift and drag coefficients are measured. They are then published in a book like this one for future aerospace engineers to decide which airfoil best suits their purpose. The question as to why the pressure happens to be lower on the top compared to the bottom of the wing is not really that important. Heaps of empirical data show that it is the observed phenomena, and we work with it from there, as unsatisfying as that may be.
  • 7
    $\begingroup$ I beg to differ! Empirical work is needed in fields like medicine where we understand too little to make logical conclusions, but aerodynamics is really well understood so deductive reasoning gets you to the best result more quickly. Also, you fail to answer the original question, which is whether wrong concepts are still taught in flight school. Maybe you want to add to your answer in order to improve it. $\endgroup$ Aug 23, 2014 at 10:23
  • $\begingroup$ I agree that aerodynamics is well understood, but just because it is well understood does not mean that you do not benefit immensely from empirical data. As for the original question, the way I learned it is that air flows faster over the top, leading to less pressure, leading to an upward 'pull' on the wing. The curvature of the wing allows for this to happen. As for Bernoulli/Newton, etc, they dont seem to describe this relationship between wing shape and lift, which is why it is unsatisfying for me. OTOH the lift coeff, which seems to relate the 2, is found mainly through empirical tests. $\endgroup$
    – Greg
    Aug 23, 2014 at 11:19
    $\begingroup$ I agree that having looked at a lot of empirical data will give you an intuitive "feel" for what is right. But not understanding the underlying physics behind it robs you of the capability to extend this knowledge to new situations. Then you are in a similar position to a pilot trained in Japan: You are excellent at performing well-trained procedures, but if something happens which you did not train in advance, you are helpless. $\endgroup$ Aug 23, 2014 at 11:25
    $\begingroup$ The actual question is "Is it taught this way in flight schools". This answer doesn't seem to address the question. $\endgroup$
    – Steve V.
    Aug 23, 2014 at 13:06
I was taught at Civil Air Patrol flight school in 1958 that the Bernoulli effect was the only way that a wing generates lift. I don't remember what our textbook was except that it was also used by the USAF. Our instructors obviously felt that this fact was not vital, and it appeared on no exams. As Steve V. says, we really didn't worry about how a wing works.
A model airplane builder in our town flew a craft that was nothing more than a flat metal disk plus an engine, rudder, and elevons. It had a very long takeoff roll and was a beast to fly, but it was clearly flying the wing and not just hanging on its prop. It was, in fact, a 25" enameled steel Texaco Gas sign. No Bernoulli effect was possible.
Also, we had seen many technical drawings of early Wright, Santos-Dumont, and Curtis aircraft, all with flat or curved wings of constant thickness over practically the whole chord. Clearly these aircraft did not generate a Bernoulli differential. We had lots of evidence that Bernoulli was not necessary for heavier-than-air flight.
So I would say that this misconception was taught in some flight schools in 1958, but it did little actual harm. Students who wanted to just fly ignored it and got on with just flying. Students who were interested in aeronautical science already knew not to accept any such simple explanation where fluid dynamics is concerned.
  • $\begingroup$ The whole 1990s controversy started because Dr. Klaus Weltner tried to get the "transit time" stuff removed from European cert. exams. Also I note that thin flat "barn doors" fly entirely by Bernoulli Effect. See JS Denker's physics page, showing that the air flows much faster over the top than the bottom. av8n.com/how/htm/airfoils.html#sec-circulation (And, "Bernoulli Explanation" is not about camber, or about thick wings. The Wright Flyer had canvas wings where the upper and lower paths were the same, yet still the air flowed much faster over the top.) $\endgroup$
    – wbeaty
    Nov 3 at 7:35
