And also what is the difference between saw tooth and dog tooth leading edge? Like is there any difference in the number of "zig-zag" patterns on the wing?
    $\begingroup$ Hi and welcome to Aviation.SE Feel free to take the tour aviation.stackexchange.com/tour Also you might want to consider adding pictures or links. And maybe dont ask different questions in title and body $\endgroup$ – Arcfrostt Dec 8 '20 at 13:07
Both terms (“zig-zag” or “dogtooth”) designate the same leading edge aerodynamic design, and are used interchangeably. “Saw-tooth” is also used to indicate the same leading edge pattern, yet it is also used in naming a specific trailing edge design (a “saw-tooth” trailing edge; see this paper which explores this effect: Saw-tooth, or, Serrated trailing edge
The number of “cuts” (or, extrusions of the leading edge of a certain wing section compared to the leading edge towards the root of the wing) are a choice of design.
The “dogtooth” (or “sawtooth”, or “zig-zag”) at the leading edge acts in a way similar to a wing fence ), inducing an effect on the relative airflow which acts to prevent span-wise flow (and also adds energy to the air flowing over any control surface in the area, increasing its effectiveness. As there are aircraft with numerous wing fences, so can the dog-tooth extrusion be multiplied on each wing, however, it is a question whether there were any planes out there with more than three such points of extrusion.
See this question for more detail: Hawker Hunter Dog-tooth wing - Aviation SE
Take a look at these pictures: notice the “dog-tooth” / “saw-tooth” leading edge and “saw-tooth” / “serrated” trailing edge.
Leading edge wing aerodynamic devices Pic2 Pic3 Pic4, saw-tooth leading edge with illustrated vortex Trailing edge serration Pic2
