I was hoping to get a few answers regarding how to read a FAA departure procedure chart. Let's take the JUDTH SEVEN DEPARTURE chart shown below:
From what I can tell, it seems that the diagram in the upper left indicates that those taking off from either runway 3 or runway 21 should make an appropriate turn to heading 335 degrees. Is this correct?
Following the "thence...," it says to expect RADAR vectors to GBN VORTAC. So does this mean ATC will guide the aircraft to the GBN VORTAC fix?
Can someone explain what MOHAK TRANSITION (JUDTH7.MOHAK) means? Is this saying that the MOHAK fix represents a transition to en route airspace from terminal airspace?
How would one identify the departure fix in this chart and in general? Is the departure fix MOHAK? JUDTH? GILA? Additionally, what would be the departure procedure transition fix?
Thanks!
