What is the relation between sweep angle and lift-to-drag ratio?
And does it depend on the wing planform?
For subsonic speeds.
Sign up to join this communityWhat is the relation between sweep angle and lift-to-drag ratio?
This is my take on this.
We assume that an infinite-span swept wing is under compressible flow, and that the flow acts on it as in Figure 1 below:
With that, we can now utilize the equation of motion to find the relation between the sweep angle and the coefficient of lift, which in turn, will make the relation with the ratio L/D
From the equation of motion, we have:
$$(1-M^2_{\infty}\cos^2\Lambda)\frac{\partial^2 \phi}{\partial x^2} + \frac{\partial^2 \phi}{\partial y^2}$$
Now, only the perpendicular component acts we have that:
$$(u'_c)_n = \frac{\partial \phi}{\partial x} = \frac{1}{\sqrt{1-M^2_{\infty}\cos^2\Lambda}} \frac{\partial \Phi}{\partial x} = \frac{(u'_i)_n}{\sqrt{1-M^2_{\infty}\cos^2\Lambda}}$$ $$C_{p_c} = -2\frac{\cos\Lambda(u'_c)_n}{U_\infty} = -2\frac{\cos\Lambda(u'_i)_n}{U_\infty\sqrt{1-M^2_{\infty}\cos^2\Lambda}}$$
Now, since:
$$C_L = \frac{1}{c}\oint C_p dx$$
We have that:
$$C_L = \frac{C_{Li} }{\sqrt{1-M^2_{\infty}\cos^2\Lambda}}$$
The above equation shows that the lift coefficient is sweep angle dependent, therefore, the ratio L/D is also sweep angle dependent.
This is a very complex side of aerodynamics and understanding it completely requires some study. I recommend studying Chapter 11 from "Fundamentals of Aerodynamics" by J. Anderson (a classic) and Chapter 8 from "Aerodynamics for Engineering Students" by E.L. Hughton.
The answer depends on the Mach number and the angle of attack. At low speed significant sweep provokes earlier boundary layer transition which negatively affects L/D, but at transsonic speed it delays shocks and improves L/D. At high angle of attack a swept wing will stall earlier and reach lower maximum lift, except for delta wings.
Sweep will transform bending moment into torsion and requires a stiffer wing, and it lowers maximum lift and the lift curve slope, so for the same landing speed a swept wing must be larger. This drives up wing weight for the swept wing and, indirectly, drag. Therefore, an unswept wing in subsonic flow will produce the best ratio of useable lift over drag.
For completeness: At low supersonic speed, when leading edge sweep is larger than the Mach cone angle, flow around the wing is still similar to subsonic flow and the leading edge thrust resulting from this greatly improves L/D. Once the Mach cone angle is larger than the sweep angle, flow is fully supersonic and L/D is little affected by sweep.
Back to subsonic flow:
At low sweep angles (< 20°) the impact on the stability of the boundary layer is low and very little change in L/D can be noticed at low and moderate angles of attack. The effect depends also on the Reynolds number and is largest between Re = 500,000 and 5,000,000 when significant laminar runs are possible but the boundary layer can be tripped rather easily.
Explanation: The acceleration of the flow normal to the lines of equal chord and deceleration from viscosity produce a 3D speed profile in the boundary layer which is twisted. This favors earlier turbulent transition.
Below approximately Re = 500,000 the laminar boundary layer is more stable and can lead to large separation bubbles or outright laminar separation, so active tripping of the boundary layer improves L/D. Sweep will not affect this.
Above approximately Re = 5,000,000 the boundary layer trips by itself rather quickly and again sweep will not affect this significantly.
At high angles of attack sweep will reduce lift at the wing's center and lead to early flow separation at the wingtips from a tipwise flow of the boundary layer. Now sweep can be very detrimental to L/D but its effect on the pressure distribution can be somewhat mitigated with changes in the airfoil and incidence over span.
At very high sweep angles and angles of attack you get flow separation at the leading edge and vortex lift when a straight wing would simply show separated flow. However, due to the reduction in the lift curve slope with increasing sweep angle, and the loss of nose suction at high angle of attack, LD in this condition is rather low.
Wing sweep delays compressibility effects. When we assume an infinitely long wing as in the top image below (Torenbeek Fig 7-19), the pressure distribution would be determined by the velocity component over the leading edge only.
According to this simple wing sweep theory, the following effects occur:
So according to simple sweep theory, the normal section shape must be designed at a higher $c_l$ than the wing lift coefficient. From Torenbeek page 247:
For example, a wing sweptback by 35 degrees, and operating at M = .85 and C$_L$ = .4, will have normal sections designed for operation at M=.7 and C$_L$ =.6.
There are quite a few factors in optimising a wing, particularly a swept wing:
Sweep of a rectangular wing
Therefore we'll leave Torenbeek's design reference book alone for now, and have a look at the effect of wing sweep only on an untapered, untwisted wing.
If a rectangular planform wing is swept by angle $\Lambda$, the wing span decreases by factor cos$\Lambda$. And then using the quadratic approximation equation for induced drag $C_D = C_{D0} + \frac{{C_L}^2}{\pi Ae}$, $C_D$ increases with a factor 1/cos$^2\Lambda$. Using some values for a 1970 subsonic jet:
Note that this is a simplified approximation:
