10
The image is from: BBC Skies Above Britain Series 1 "Flying into Danger" - Episode 1 enter image description here
    $\begingroup$ "is there a website for aircraft identification?" Yes, this one :) We love aircraft identification questions here. $\endgroup$
    – Bianfable
    Nov 15, 2020 at 10:52
    $\begingroup$ Unless it's obviously some bad photoshop where there's 20 jet engines on a cessna 172 @Bianfable. $\endgroup$
    – GdD
    Nov 15, 2020 at 17:06
  • $\begingroup$ @GdD For better or worse, we sometimes even deal with photoshops $\endgroup$
    – Jamiec
    Nov 16, 2020 at 17:21
  • $\begingroup$ I know @Jamiec, we don't love them though. $\endgroup$
    – GdD
    Nov 16, 2020 at 20:10
15
Although a little hard to read, the reg is F-BXCP which you can find with a search
https://www.airport-data.com/aircraft/F-BXCP.html
The aircraft is a Max Holste MH.1521 Broussard which is a 1950's era aircraft originally built for the French airforce.
Somewhat interestingly that aircraft is now registered G-HOUR and is owned by the luxury watchmaker "Bremont" (hence the reg). It seems to have first got a reg-change with the same paint scheme and then latterly been repainted.
