For an aircraft with both jet and propeller, how do we calculate the maximum rate of climb? I know the equation of maximum rate of climb, velocity, and angle for propeller and jet, respectively. But I don't know how to mix the two set of equations together.
$\begingroup$ Once you know how combined thrust changes over speed, you can use the equations in this answer $\endgroup$ – Peter Kämpf Nov 15 '20 at 4:55
Add a comment
