If not, why not? For example, if a civilian jetliner is flying at night over the Ocean, or a remote area with no airports/ground radar stations, and another airplane is also heading towards it on a collision course, shouldn't the pilot be able to spot the oncoming airplane on its airborne radar to perform evasive maneuvers? My understanding is that military aircraft have such airborne radar, which I believe is called ACAS, so they need not depend on ATC/ground stations for collision avoidance.
  • $\begingroup$ Air Traffic Control is responsible for preventing collisions. In areas where there s no ATC, pilots position reports, traffic advisories, and TCAS do a good job preventing collisions. Airborne Weather Radar actually will pick up another aircraft, but it can’t be relied on for accurate positioning. $\endgroup$ Nov 7, 2020 at 2:51
Radar that can detect, resolve and track small targets as opposed to large areas of water (raindrops) has to be a lot more powerful and sophisticated, especially in ye olden tymes of the 50s and 60s when weather radar was becoming a thing and the search for a practical collision avoidance system was underway.
When the effort that eventually became TCAS got started in the late 50s following several notable midairs, on-board target detection was one of the early proposals but was rejected by the industry as too expensive and time consuming to develop (where to put the more powerful system with its larger antenna for starters).
Once TCAS was perfected, made possible by the development of Mode C altitude reporting by transponders, you got 95% of the benefit (because only non-Mode C-transponder light planes were still a risk - a very minor factor overall once Mode C was pushed out to GA aircraft) without a crazy expensive addition of on-board target detection and tracking radar PLUS a weather radar.
Cessna Citation I weather radar Cessna Citation I weather radar.
SOCATA TBM 900, weather radar housed in the pod on the left wing SOCATA TBM 900, weather radar housed in the pod on the left wing
Weather radars are tiny compared to fire control radars. I believe this is because they do not need to collect as much info about their target as fire control radars. Further, they do not need to produce beams as narrow or as fast-moving as FCR's. Keep in mind that raindrops move much slower than aircraft, thus a weather radar does not need to track a flanking (moving sideways relative to the observer) target at 500 knots.
Zaslon AESA radar of the MiG-31, 1.4 meters in diameter Zaslon AESA radar of the MiG-31, 1.4 meters in diameter.
FCR's consume significant electrical power and they require constant attention from their operator to be directed to a certain part of the sky and be effectively used.
With TCAS/Mode C transponders onboard most aircraft, there is simply no reason to put an FCR on an airliner or any civilian aircraft for that matter. Most airliners don't even have a large enough radome to put an FCR in.
No, TCAS does not rely on ground based radar stations and it works perfectly well at night over the ocean. Each aircraft broadcasts messages, which include altitude, and listens for messages from other aircraft. If TCAS receives messages from another aircraft nearby that operates at the same altitude, it warns the pilots and advises them to climb or descend.
Unlike radar, TCAS only works if both aircraft are equipped with it.
    $\begingroup$ The question isn't about TCAS even though it has that tag. It simply asks if commercial aircraft have radar that can detect other planes. $\endgroup$ Nov 7, 2020 at 2:14
  • $\begingroup$ @CareyGregory that is correct. Perhaps I should remove that TCAS tag. $\endgroup$
    – Mr X
    Nov 7, 2020 at 2:42
    $\begingroup$ TCAS is a form of radar. Also, the last sentence of this answer is incorrect - TCAS does not require both aircraft to be equipped with it. It's sufficient for one of the aircraft to have TCAS and the other to have a Mode C or Mode S transponder. $\endgroup$ Nov 7, 2020 at 3:53
