This is the first Cessna Skycourier during certification. Why are the two exhausts oriented upwards?
The rotation direction of the propellers produces a rotating slipstream. This slipstream pushes the exaust from the (engine's) right side downward, but the exhaust on the other side would be pushed up, producing potential heat problems where it impinges on the wing (as well as depositing lots of soot). By bending the exhaust pipe upward as you see, the exhaust on that side passes over the wing, in an airstream that will both protect the wing surface from the exhaust heat and reduce soot deposition.
  • $\begingroup$ So both comments and the answer answered my question, to whom do I give credit? I'd like to give each person due credit. $\endgroup$
    – Raffles
    Oct 20, 2020 at 19:54
    $\begingroup$ @Raffles This is why these sites discourage answers in comments (links to duplicates are a special case): we can't vote them up or down or give the author credit/rep. $\endgroup$
    – Zeiss Ikon
    Oct 26, 2020 at 11:19
