I believe hot wire anemometers (HWA, frequently used in wind tunnels to measure flow velocity) or other sensitive techniques could be used to determine the airspeed. Are there specific reasons for why the aircraft industry continues to use pitot-static instruments? Or is it just tradition?
A nice link on HWA's: The hot wire anemometer
    $\begingroup$ My suspicion is that pitot tubes are extremely robust. By their nature, there's no air flowing through the tube and thus there's little risk of debris building up and blocking it. (Although I have had mudwasps build a nest in my pitot tube, which caused much hilarity when it clogged shut immediately after rotation.) $\endgroup$ Oct 18, 2020 at 16:22
    $\begingroup$ What would be the advantages of changing, and would those advantages outweigh the costs? Remember the old adage: "If it ain't broke, don't fix it". $\endgroup$
    – jamesqf
    Oct 18, 2020 at 16:40
  • 11
    $\begingroup$ The pitot (more exactly: Prandtl) tube measures exactly the quantity which determines lift: Dynamic pressure. A hot wire or laser backscatter measurement has interpretation steps involved which the Prandtl tube doesn't need. $\endgroup$ Oct 18, 2020 at 18:08
  • $\begingroup$ We have two closely related questions on this: here and here. Does one of them help? $\endgroup$
    – Pondlife
    Oct 18, 2020 at 19:52
  • $\begingroup$ @Pondlife They are similarly themed but I think the posted here is a lot more helpful. Thanks tho! $\endgroup$ Oct 19, 2020 at 4:02
4 Answers 4
15
The linked article says that an HWA (hot-wire anenometer) is
fragile and requires complex equations to relate the sensed value to the fluid speed as well as correct for inherent, unavoidable nonlinearities as well as external factors such as fluid type, ambient temperature, humidity, and angle between the flow and the sensor.
Conditions in a wind tunnel or other lab equipment are far more predictable, and change much more slowly and much less, than those encountered during an outdoor flight through variable weather.
Although industrial variants of the HWA don't expose the fragile sensing wire to damage or dirt accumulation (the dirt as thermal insulation causes the sensor to report incorrectly; rain or ice would still affect an aircraft-mounted one), they still need to correct for density, humidity, temperature, and flow angle. A four-dimensional lookup table takes a lot of work to create and store. Outside the lab the pitot tube is more reliable, even if it is more "primitive."
HWAs have been flown, but only as test equipment, not as sensors for primary flight instruments. For example, this set of HWAs flew on an F-15B to characterize flows in the boundary layer, sampled many thousands of times per second, far more sensitive than a pitot tube. But between each 30-second measurement interval, the HWAs were retracted inside the airplane for protection.
  • $\begingroup$ Thanks for the answer. A very interesting point on them being used on the F-15! $\endgroup$ Oct 19, 2020 at 4:04
Hot wire anemometers are great for measuring turbulent fluctuations on a very fine timescale (say kHz). This is really not needed for aircraft speed. The very same wind tunnels that use HWA or LDA (laser Doppler anemometry) or PIV (particle image velocimetry) for detailed measurements themselves usually use Pitot tubes to measure the reference windspeed in the tunnel. It is robust, remains calibrated and will smooth out the fine turbulent fluctuations, which is actually a good thing if you are interested in the speed only.
There are quite a few reasons. First off, as everyone has already mentioned, HWAs are quite fragile and somewhat more complicated to decode (though the latter is a non-issue with modern electronics). More importantly though, a pitot-static measurement offers some distinct advantages specifically as far as aviation is concerned.
On the face of it, a pitot-static system is very simple, both in concept and implementation. A typical integrated pitot-static tube measures total pressure at the pitot port and has a series of equally spaced holes around its circumference (in the cylindrical portion) to measure static pressure. In common use are also pure pitot tubes, wherein a static reference comes from the static port altimeters are connected to.
It is important to note that the tube itself does no measurement. Merely, it provides a reference location for a sensing element to be connected via pipework of some type (usually a mixture of rigid and flexible hose, depending on the application). It is at the sensing element where the magic happens.
When a differential manometer is connected across the total and static references, it is able to directly measure dynamic pressure in that location. This follows from incompressible flow and the Bernoulli equation, namely $P = p + q$, where $P$ is total pressure, $p$ is static pressure and $q$ is dynamic pressure. Upon expansion, $q = 1/2 \rho U_{\mathrm{inf}}^{2}$ where $U_\mathrm{inf}$ is the free stream velocity of the airflow giving rise to $q$, and rho ($\rho$) is the free stream air density.
When we assert a constant rho of 1.225 $kg/m^3$, we can rearrange for free stream velocity: $U_\mathrm{inf} = \sqrt{2 q / \rho}$, or if we factor out $k = \sqrt{2 / \rho}$, $U_\mathrm{inf} = k \sqrt{q}$ - a simple square root relationship which can be implemented mechanically or in software quite easily.
Where this is particularly useful is in aerodynamic calculations during flight. As every important flight parameter (lift, drag, control input, etc.) is directly correlated to $q$, having an indicated airspeed (IAS) also directly correlated to q simplifies a pilot's job drastically. There is now ONE stall speed for each configuration. The feel of the aircraft is exactly the same, no matter the air temperature, the list goes on. The value of this simplification in reducing pilot workload cannot be overstated.
This is why, for any normal flight operations outside navigation, indicated airspeed derived from directly measured dynamic pressure is by far the most useful speed measurement to have. Navigation is secondary and for that there are conversion tables, DME and GPS.
It should be noted, that the raw $q$ measurement from the pitot-static system is almost never left unadjusted for commercial and military applications. Anything from the pitot port's position to compressibility effects must be adjusted for in order to preserve the IAS relationship a pilot expects, which is why modern commercial and military aircraft first convert IAS to calibrated airspeed (CAS), which accounts for the pitot-static system's position error and then into equivalent airspeed (EAS), which further accounts for compressibility as soon as the incompressible flow assumption breaks down (usually at any Mach number above 0.3).
It should further be noted that both Reynolds number (related to true airspeed or TAS) and Mach number will have an effect on aerodynamic forces, but those effects are usually small (during subsonic and low transonic flight) compared to the effect of dynamic pressure and may or may not be accounted for in other ways (i.e. adjustments to the fly by wire system, if present).
  • $\begingroup$ Welcome to Aviation SE! I admire your technical-but-readable writing style. $\endgroup$ Mar 23, 2023 at 16:05
  • $\begingroup$ Thanks, happy to help! $\endgroup$
    – Kostadinov
    Mar 24, 2023 at 16:07
Most modern car engines have a computer to balance fuel-air mixture, ignition timing and other factors to give best performance or fuel economy. A hot-wire Mass Air Flow (MAF) sensor is a very common way to supply air flow data, there are also cold-wire versions. Although they are very reliable for that application there are a few issues which would make them less than ideal for aviation:
  1. They are relatively fragile, fine for automotive air flows but they wouldn't stand up to higher air flows
  2. They are sensitive to oil, aerosols and other airborne contaminants which would effect their accuracy. These accuracy issues can be hard to detect as they aren't outright failures. In a car an inaccurate air flow sensor leads to inefficient combustion which limits power and efficiency, in flight inaccuracy would be a major safety issue
  3. Cold wire systems are slower to respond to airspeed changes
The electrical airspeed sensors I know of are all pressure transducers, which are accurate and don't have the flaws I listed above.
The thing you also have to be aware of is that hot or cold wire systems need a laminar flow of air to be accurate, you'd still need a pitot system or something similar to direct the flow of air over the sensor for it to give the correct reading.
Of course, the biggest drawback to any computerized sensor system is that they are reliant on electrical power.
    $\begingroup$ HWA sensor in cars benefits from at least 3 additional advantages: An air filter to limit the dust in the airflow, no need for an absolute (long-term) stability and frequent shutdowns of the engine when a maintenance (by self-heating) can be performed. It is also clearly not that much important - the engine can be acceptably controlled by the MAP (pressure sensor) alone. Not to say that the car is inherently safe even with completely failed engine. $\endgroup$
    – fraxinus
    Oct 19, 2020 at 8:19
  • $\begingroup$ Not disagreeing with you @fraxinus, I would say that many non turbo cars don't have a MAP, if the MAF fails the ECU falls back to static maps. The engine will still work with reduced power and/or efficiency. $\endgroup$
    – GdD
    Oct 19, 2020 at 8:26
  • $\begingroup$ Also, there would seem to be a considerable amount of redundancy in the automotive case. The air flow sensor isn't the only sensor in the system. If it reads too low, the exhaust sensors will detect a too rich mixture, and the ECU could be programmed to correct for it. Using it as the direct source of air speed means there is no redundancy. (Other than "seat of pants" flying, of course.) $\endgroup$
    – jamesqf
    Oct 19, 2020 at 17:09
  • $\begingroup$ Not really @jamesqf, the computer may know something is wrong but often times you'll have to some detective work to trace what's going on. But, it isn't critical. With an aviation application you'd have at least 2 of everything important anyway, but as we've seen that doesn't always solve the problem $\endgroup$
    – GdD
    Oct 19, 2020 at 20:10
  • $\begingroup$ "The thing you also have to be aware of is that hot or cold wire systems need a laminar flow of air to be accurate" This is nonsense or some serious misunderstanding. Hot wire systems are the best instruments to measure turbulence on very fine time scales. They are the most important type of instruments that were used to study the fundamentals of turbulence for decades. $\endgroup$ Sep 13, 2023 at 22:08
