In the type certificate data sheet for a jet engine, there is this table enter image description here
static thrust is the thrust generated by the engine when the plane is at rest with respect to the Earth and the surrounding air. So why would it have different values? And is the plane still "at rest" at these values?
Also, what is the different between thrust and sea level static thrust here? enter image description here
It is from http://aerodesign.stanford.edu/aircraftdesign/propulsion/tvshv.html
The static thrust value is with the engine fixed in place in still air. Imagine the engine on an outdoor test stand, or on an airplane with the brakes on or tied down. As soon as the airplane starts to move, the thrust value declines and the static thrust value no longer applies. The static thrust value at sea level is used because it provides a consistent baseline reference, because once the engine starts to move, additional variables come into play.
The lower chart is showing the relative decline in thrust with speed for the range of engines between pure jet (bypass ratio = 0) to very high bypass (5-6), to illustrate the impact of bypass ratio on the decline in thrust with speed. "Static thrust" is implied at the speed value of 0 Mach (airspeed is zero, so you are "Static" by definition) as a value of 1 and declines in thrust from static are a value less than 1. So you can interpret the left edge of the chart as "static thrust" and everything to the right as (moving) thrust, with the curves going down and recovering (or not) with increasing Mach #.
It's just illustrating relative effects, so with 6 engines that have different bypass ratios, their decline with speed, from the engine's Sea Level Static Thrust (whatever it is, represented by the value of 1), is shown by each curve. Following the curves as an example, the pure jet has only lost about 7% of its rated static thrust with speed at Mach 0.5, whereas the very high bypass fan has lost over 40% of its static thrust value at Mach 0.5, in the same atmospheric conditions.
  • $\begingroup$ the name is called "take off (5 minutes)" because take off requires more thrust than cruise? $\endgroup$
    – user39178
    Oct 4, 2020 at 1:32
  • $\begingroup$ So is the sea level static thrust in the graph representing the "take off (5 minute)" value or the "maximum continuous" value? $\endgroup$
    – user39178
    Oct 4, 2020 at 2:24
  • $\begingroup$ Yes takeoff thrust is always more than max continuous because takeoff requires the most performance. I would assume any value quoted as static thrust is a takeoff thrust value, since the static condition, operationally, represents the beginning of the TO roll. To get decent takeoff performance, the engine maker is granting permission you might say, to flog the engine much harder than normal as long as that is limited to 5 min, and not reduce the engine's minimum life expectancy. You will however maximize life by reducing the max thrust where possible, which is where "flex thrust" comes in. $\endgroup$
    Oct 4, 2020 at 3:54
Turbofans use a gas turbine core to drive the low pressure fan which produces most of the thrust by moving large volumes of air. This requires large amounts of torque which the low pressure turbine extracts from the hot exhaust gases exiting the gas turbine's core.
To develop more power you burn more fuel which means more heat. Low pressure gas turbine blades are usually rated over 2000F meaning they will melt if exposed to too much heat.
The reason for the rated 5 minutes of thrust is simply because the turbine blades will overheat causing premature wear and possibly engine failure. To produce the rated thrust the turbofan is at sea level in stationary air hence the term "static".
As the forward airspeed increases and the density of the air reduces due to increased altitude the rated thrust will go down which is not represented in the chart.
  • $\begingroup$ so even though the term contains "static", the aircraft is still moving forward at take off speed? $\endgroup$
    – user39178
    Oct 3, 2020 at 22:37
  • $\begingroup$ The aircraft is not moving in a static test. $\endgroup$ Oct 3, 2020 at 23:06
  • $\begingroup$ but is the engine fixed to the ground or the thrust value is just the maximum thrust it could produce without the plane started moving? $\endgroup$
    – user39178
    Oct 4, 2020 at 0:06
  • $\begingroup$ It's the maximum thrust developed in a test where the engine was fixed (probably on a test stand) with given power levels. "take-off" in the first chart refers to the power setting, not to the motion of the engine. $\endgroup$
    – BowlOfRed
    Oct 4, 2020 at 0:38
  • $\begingroup$ in the graph above, is the sea level static thrust the "take off (5 minute)" value or the "maximum continuous" value $\endgroup$
    – user39178
    Oct 4, 2020 at 3:01
