13
I saw this video and was wondering how he is controlling the plane:
It looks like he only has ailerons. It does look like he is shifting his body weight. Is that the answer? If so, that's pretty surprising! But I guess it's like a hang glider?
Does anyone know how you should shift your body to increase/decrease pitch, and increase/decrease yaw?
    $\begingroup$ The whole device shown in the video is quite scary. What protection exists for the pilot when landing in a field in an emergency where the likelihood of the plane toppling over is quite real? And how did they pan and zoom the installed cameras? Remote control? $\endgroup$ Sep 24, 2020 at 7:57
    $\begingroup$ @PeterKämpf - What? I take it that you don’t think the Walmart bicycle helmet is enough? 😜 $\endgroup$
    – Dean F.
    Sep 24, 2020 at 8:22
    $\begingroup$ As Peter Kampf has said, the aileron control surfaces also act as elevators. I wonder if the body movement is negligible or necessary. Does the weight shifting aid in countering adverse yaw? Or, is there a greater degree of deflection when the aileron is up versus when it is down? Is the difference adjustable in flight? If not, does that affect the aircraft’s crosswind capability? After all, there are aircraft like the Eurocoupe and flying wings that fly without rudders. $\endgroup$
    – Dean F.
    Sep 24, 2020 at 8:29
    $\begingroup$ Limited market for this craft as young Anakin Skywalker is the only human who can fly it. $\endgroup$ Sep 24, 2020 at 17:20
    $\begingroup$ @quietflyer According to this interview (Warning: Japanese), the harness does control roll through control cables to the ailerons, but pitch is entirely done through shifting the CG. The throttle is in a handle on the pilot's right. $\endgroup$ Sep 24, 2020 at 18:15
4 Answers 4
11
The ailerons in most flying wings can also move together up and down, then working as an elevator. This is called an "elevon", combining both words as the device is combining both functions. Since flying wings mostly use reflex airfoils, loads on the rear part of the wing tend to be small and the force to keep elevons at their right deflection is small, too. In case of the SB-13, they are pre-loaded by a small, adjustable spring but otherwise free-floating. In this case, however, it could be that they only work as ailerons.
When used for pitch control, elevons must move up and down together on both sides. This means they will be freely floating and must be held in position by some force. It would be easier to cross-link them so they only can move against each other, and then they only work as ailerons.
The airplane, called OpenSky M-02, is the brainchild of Tokyo University of the Art professor Kazuhiko Hachiya and has been built by Aircraft Olympos of Japan. OpenSky M-01 was a lighter, unpowered version.
As Louise Hose writes on Kitplanes:
Hachiya designed the project and is the only pilot to fly the resulting “Open Sky M-02J”. He started with a hand-launched, scale model to test the airfoil characteristics. Once he was satisfied with the basic design, he partnered with aeronautical engineer Tota Ueno of Olympos Company in Tokyo to scale up to a glider capable of carrying one person…Hachiya himself. The glider, first flown in 2006, was launched from the ground by teams of people pulling a bungee cord. Once satisfied with its flight characteristic, Hachiya and Ueno worked to find the “right” engine to add as the powerplant. Between 2010 and 2013, they were doing high-speed taxi tests and working through issues…particularly powerplant and regulatory issues. They ultimately decided to use the NIKE jet engine made by AMT Netherlands which produces 176 pounds force. The jet was designed and mostly used in target drones.
At least the model couldn't be steered by weight shifting, and looking at the harness of the pilot, his capacity for weight shifting is rather limited. My impression is that weight shifting is primarily used for ground control. If you watch the YouTube movie, it becomes apparent that he is barely capable of controlling the direction on the ground, and has to lean to the left on take-off to prevent it to escape the runway. Also, his movements are more sideways than back-and-forth. The control surfaces hardly move, but show linkages on the bottom side, so they are moveable. If you look closely, you can see pulleys on the left and right of the pillow Hachiya-san is lying on, and as @quietflyer says, they should control the elevons, but he adds his weight to help controlling both pitch and roll.
Louise Hose of Kitplanes again:
To date, Hachiya has made about 150 “jump” flights and 70 circling flights. He has flown it up to nearly 500’ agl but believes it can fly much higher. (Airspace restrictions in Japan have prevented him from trying to fly higher.)
  • $\begingroup$ The ailerons are a little too close to the pitch axis to provide meaningful pitch control. It's pitched with weight shift. $\endgroup$ Sep 24, 2020 at 17:34
  • $\begingroup$ @HiddenWindshield If you really believe that, then study flying wings like the AV-36 more closely. With the little pitch inertia and damping of a straight-wing flying wing, all it needs is a change in the pitching moment coefficient of the airfoil. $\endgroup$ Sep 24, 2020 at 17:39
  • $\begingroup$ Yes, elevons in this configuration could provide some pitch control, but not enough to be practical. The AV-36 has a much longer chord, moving the elevator further back from the CG. And Hachiya himself has said (note: you'll need a translator service unless you read Japanese) that pitch control is done by moving the center of gravity. $\endgroup$ Sep 24, 2020 at 18:09
    $\begingroup$ @HiddenWindshield: I have now studied the video a bit more and it is obvious that the pillow the pilot is lying on has pulleys connected left and right. By shifting his body around, he will be able to deflect the elevons both symmetrically (for pitch) and against each other (for roll). Weight helps, but is not all. The elevons have their fair share as well. Also, being mounted on the inner wing segment only, those surfaces make rather inefficient ailerons. $\endgroup$ Sep 24, 2020 at 18:25
    $\begingroup$ @HiddenWindshield Thinking a bit more about this, the pulleys are much better for roll control than pitch. Also, for pitch the control surfaces must be free-floating while to serve as ailerons only they can be linked so they can carry a load without floating up or down. I guess you are right, in that case they really are only ailerons. $\endgroup$ Sep 24, 2020 at 18:29
This is the M-02J, a jet plane modeled after the Mehve "glider" (actually a futuristic antigravity plane) from "Nausicaä of the Valley of the Wind". And, yes, the pilot controls pitch primarily by shifting his weight forward and back, while the ailerons are only used for roll control.
You can control any airplane through weight shift, that's not limited to hang gliders. It's just not practical for larger aircraft, but for little one-man planes, it's perfectly reasonable.
To answer the last question, it works just like a hang glider. The plane's pitch and roll can be controlled by shifting your weight in the direction you want to turn. Yaw isn't controlled, you just have to rely on the natural aerodynamics of the aircraft to keep your nose pointed in the direction of flight.
    $\begingroup$ Case in point. If you are flying right seat in a small, GA aircraft like the Piper Cherokee/Warrior/Archer variety, you can make a trimmed out straight and level aircraft climb by reclining your seatback. $\endgroup$
    – Dean F.
    Sep 24, 2020 at 18:31
    $\begingroup$ Kudos for correctly identifying the origins of the plane! $\endgroup$
    – Jpe61
    Sep 24, 2020 at 21:30
The Kitplanes article suggests that the pilot's left-right (and fore-and-aft?) body movements shift the small platform or cradle that he is lying on, which pull on the control cables that actuate the ailerons or elevons, whichever they are. No joysticks appear to be involved. We lack an authoritative answer as to whether pitch control is primarily/ partially via elevons or solely weight-shift, but the former seems more likely. Even if pitch control is mainly through elevons, the effect of even a slight fore-and-aft shifting of pilot's shifting body weight may not be negligible on a tailless aircraft with little or no wing sweep.
Note that the system is reminiscent of the hip cradle used in the Wright brothers' earliest aircraft, at least as far as roll control goes.
Yaw control is a non-issue with many well-designed aircraft. For example, very few hang gliders have had yaw control surfaces.
  • $\begingroup$ Excellent observation. If you look closely, there are pulleys connected to the pillow on which Hachiya-san is lying. $\endgroup$ Sep 24, 2020 at 18:19
  • $\begingroup$ @PeterKämpf and quiet flyer: I'm pretty sure they're elevons. I think I've reverse-engineered a plausible design for how those ropes are hooked up to them, which I posted as an answer. It might not be correct, but I think it's plausible. $\endgroup$ Sep 25, 2020 at 17:39
I think I see how the elevon controls are designed. The pulleys by the pilot's waist look independent, except for being connected to the sides of the "pillow" the pilot rests his torso on. So that creates linkage between controls for side-to-side or forward-backward movement.
The pilot moving his body (and thus the pillow) left or right will pull on one and create slack in the other, creating opposite changes in elevon position. This gives roll control.
Near the end of the video, after landing (e.g. at 5:00) we see a good angle of the "pillow" positioned so the cord attachment points are as close as they can get to the pulleys. So the pull on each cord is at a minimum. This is presumably downward deflection of both elevons since the pilot moved to this position after touchdown. Moving left or right could probably lower one a bit further (while raising the other). (In that same shot, we can see the elevons in frame as well, and it looks like they're not far down, but this is a bad angle. Maybe they simply don't go very far down, or there's some kind of internal linkage, or I'm missing some other control input.)
But in flight, I think the pilot generally keeps his body position farther back, so both ropes are pulled out some. This pulls the elevons up to a neutral or higher position, leaving room for pitch up or down by moving the pillow back or forward, respectively. (Along with the pilot's weight, which also provides some pitch control directly, apart from moving the elevons).
In this position, moving left and right will still slacken one and tighten the other, creating the opposite movements you want for roll control.
During landing (4:22), we have a camera angle from above/behind the pilot that shows both ropes and pulleys while he's moving, controlling pitch while maintaining some right-roll. Note how he pushes backward (tensioning the ropes) to flare a bit just before touchdown.
To make roll control work in the correct orientation, I think the right rope must be connected to the left elevon, and vice versa. Because moving your body (including bodyweight) right slackens the right rope. But to roll right, you need to deflect the right elevon up. If it was right rope => right elevon, either roll or pitch control would have to work against the pilot's weight shifts, depending on whether pulling deflected upward or downward. That would be terrible and unintuitive, and we can see from the video that he's moving and/or leaning right to roll right, and back to pitch up.
This is my explanation of how I think it's designed, not based on any statements from the designer. (But thanks to the other answers for their observations that shaped my thinking, especially @quietflyer for spotting the pulleys.) I think it's a plausible design for the controls, compatible with sanity and all the observations I could make from the video, but possibly not the actual design.
Certainly body-weight shifts are part of the controls; as @quietflyer says we can't be sure how much of the control authority comes from body-weight vs. elevons. But it looks like there is good control of the elevons for both pitch and roll.
2:50 in the video is a decent side view of exercising some pitch control (near the ground so it provides a good reference). We definitely see the pilot shift his body forward and back.
It's hard to see the far elevon. I can't tell whether it's moving as much (in the opposite direction) as the left aileron goes up and then down. If not, that would prove that these are elevons which can also do pitch control, not just linked ailerons. I think that's the case from what would make sense for the rope/pulley design, but I'm not 100% sure.
    $\begingroup$ i agree on the feasibility of this arrangement but wonder how much load is carried by the elevons in flight and whether that is compensated by a spring. In that case the pilots works against the spring, which is tolerable for short flights. When Lippisch designed his first flying wings, the same happened (without a spring, so the elevons were only held by pulling on the stick) and only after a 3-hour flight to Berlin with an early motorized version did the pilot notice that he had to pull on the stick all the time. $\endgroup$ Sep 25, 2020 at 20:33
    $\begingroup$ I think this answer is correct; looking closely at the cords and pulleys it is difficult to imagine how fore-and-aft motions of the cradle would not cause same-direction up or down deflection of the control surfaces, so I think they are indeed elevons. If you look at the video around 2:50 there is little evidence of any rolling motion so I think we are seeing the pilot shift his position strictly in the fore-and-aft direction at this moment in the video. $\endgroup$ Sep 29, 2020 at 15:30
    $\begingroup$ Truth is my answer was based more on the fact that the Kitplanes article referenced the early Wright aircraft's hip-cradle system, than a really close look at what was visible in the video; I think this answer has filled in the missing pieces as to what must be going on. $\endgroup$ Sep 29, 2020 at 15:32
