Is there any jet engines--with published data on the dimension of the turbines and compressors--that are of the configuration of 2 Low Pressure compressor, 8 High Pressure compressor, 2 High Pressure turbine, 5 Low Pressure Turbine? Thank you very much!
1 Answer
I couldn't find any that exactly match. The closest ones I found where
PW1000G-56 : 2-8 and 2-3
PD-14 : 3-8 and 2-6
What is the reason your looking for such specific architecture?
