-4
What language is Boeing's MCAS written in?
Thanks
    $\begingroup$ The answer to this question may help: aviation.stackexchange.com/questions/3608/… I'm guessing Ada in a safety critical subsystem like that. $\endgroup$
    Sep 9, 2020 at 12:54
  • $\begingroup$ As long as it is not assembler, I doubt the language itself was the main reason of the failure. I would even doubt be it assembler, if done properly, with full test coverage and code reviews. $\endgroup$
    – h22
    Sep 11, 2020 at 7:56
    $\begingroup$ Why has this question been downvoted? - I'd vote to reopen but have insufficient rep. This is not only a reasonable question, but an interesting and important one. $\endgroup$
    – stevec
    Dec 6, 2020 at 22:28
    $\begingroup$ @stevec There are a few "troll" users on here, who down-vote every question I ask without discrimination. I have stopped using the site mostly for that reason $\endgroup$
    – Cloud
    Dec 7, 2020 at 12:20
    $\begingroup$ @Cloud don't stop, your question is a very good one. Funnily, I found my way back to it when researching the 737 max a second time. Thank you for your question, even if others don't appreciate it $\endgroup$
    – stevec
    Mar 18, 2021 at 13:01
I believe the Flight Control Computer is a Collins Aerospace FCC-730 with two 16-bit processors.
Collins are known to use Ada for at least some of their products.
A job advert for Collins stated:
Job description: Sr Software Engineer - Flight Controls ...
Required Qualifications: ... Experience with C/C++ ...
Preferred Qualifications: Experience using Ada. ...
Ada is widely used in the aviation industry for flight-critical applications.
Other Boeing aircraft make extensive use of Ada:
in the 777 program it was a goal to use Ada as a standard language, and it represented nearly 70% of the source line of code developed for the 777.
So it is very likely that they used Ada for the code running in the FCC-730 on the 737 Max.
