17
Celera 500L (see Otto Aviation site for more details) is a plane with a single propeller powered by a piston diesel engine. The constructor claims it is 8 times more fuel efficient than a jet of about the same size and capacity. How is this possible? Another question would be: Is this flying apparatus at least twice as efficient as the best piston engine plane of comparable characteristics?
Otto Aviation - Celera 500L - V12 turbo-diesel laminar flow plane
General characteristics
  • Capacity: six passengers
  • Powerplant: 1 × RED A03 diesel piston engine, 550 hp (410 kW) approximate at takeoff
Performance
  • Cruise speed: 400 kn (460 mph, 740 km/h) estimated minimum
  • Range: 4,500 nmi (5,200 mi, 8,300 km)
enter image description here Claimed comparison between Celera 500L and a Jet
"[Celera 500L] is a six-person private craft that promises to fly at jet speeds, but with eight times lower fuel consumption, and a range that's twice that of a comparably sized craft."
"The company, founded in 2008 and an offshoot of Bill Otto's Otto Laboratories, says that the Celera 500L runs at 18 to 25 miles-per-gallon fuel economy (compared to the 2-3 miles-per-gallon of a comparable jet aircraft).
"Then there are the modest $328 hourly operating costs, which are about six times lower, and the generous 4,500-nautical-mile range. Maximum cruise speed is projected to reach more than 460 miles per hour."
"The reason its aircraft can do all this, says Otto Aviation, is down to laminar flow.
"Laminar flow is the minimum drag solution for aircraft surfaces, explains its website, and features smooth layers of airflow with little to no mixing of adjacent layers."
"With its aerodynamic airframe meaning it requires a lot less horsepower to achieve takeoff and cruise speeds, the Celera 500L is powered by the RED A03 engine. It has a Liquid cooled V12, twin 6-cylinder bank and, says Otto Aviation, offers best-in-class efficiency. It's certified to operate on Jet A1 and biodiesel."
Source
UPDATE:
According to a patent granted to William Otto (US9669939B2, "Aircraft supplemental thrust device and method of operating the same") Celera 500L has a service ceiling of 19.8 km!
"Propulsion of the aircraft may be provided by a fixed-pitch eight blade composite blade propeller mounted at the rear of the fuselage on the centerline axis. The propeller airfoil sections and section incidence angles are configured to provide maximum efficiency at cruise at 50,000 ft. altitude and above. Propeller diameter is also optimized for the high altitude cruise environment and as a result essentially eliminates supersonic blade velocities during low altitude operation. The optimum propeller diameter is slightly smaller than maximum fuselage diameter which coincidentally reduces the probability of bird strike and other foreign object damage. ... The aircraft cabin may be approximately 74 inches high and include an approximately 78 inch width having a minimum 50 inch seat pitch. The aircraft has a service ceiling of approximately 65,000 feet, and a normal cruise speed of between approximately 460 to approximately 510 mph, with a specific fuel consumption of approximately 30 to approximately 42 mpg depending on cruise speed and altitude. Landing stall speed is approximately 70 mph, takeoff and landing speeds are approximately 90 mph, and runway requirements are approximately 3000 ft."
I have seen on Otto Aviation's site this text:
"The Celera 500L has a glide ratio of 22:1 (typical GA aircraft of similar size have a glide ratio of < 9:1). At an altitude of 30,000ft The Celera 500L can glide up to 125 miles with no engine power. This is roughly 3x better than the typical aircraft."
and I believed that the projected service ceiling of the plane is 9.144 km not somewhere between 15.2 km and 19.8 km. At such high altitudes the air density is between 0.2 and 0.1 kg/m^3 and in consequence Celera can, in theory, reach 740 km/h with 550 hp. The Grob Strato 2C, a German experimental high altitude research aircraft, powered by two turbocharged piston engines, reached a record altitude of 18552 m on 4 August 1995, with two 6 m in diameter propellers, using a total of 800 hp.
Question: Is this altitude of 65000 or at least 50000 feet achievable by Celera 500L?
  • 7
    $\begingroup$ Only if it flies very slowly. If compared on equal footing the answer is a clear no. Current airplanes are also quite refined designs. $\endgroup$ Aug 28, 2020 at 23:00
    $\begingroup$ I would suggest editing the question down to only that which is relevant to the actual performance claims you are questioning. A link to the article would be nice for those who are interested in learning more, but there is a lot of extra marketing fluff you chose to copy/paste that has nothing to do with your basic question. $\endgroup$ Aug 29, 2020 at 0:18
    $\begingroup$ It looks like Celera 500L is an investment scam. $\endgroup$
    – Simplex11
    Aug 29, 2020 at 0:48
  • 7
    $\begingroup$ @Robert Werner, I counted around 11 paragraphs that I consider nothing more than company PR. Don’t get me wrong, it’s interesting to aviation buffs, but not pertinent to the question. $\endgroup$ Aug 29, 2020 at 1:49
    $\begingroup$ @RobertWerner This depends on the turbocharger of the engine. I would expect that it has a critical altitude of not more than 8000 m, most likely less. In order to work at full power in 20,000 m (65 kft), I would expect it to have two turbocharging stages (with humongous intercoolers which clearly the 500 L doesn't have) plus one supercharger. $\endgroup$ Sep 4, 2020 at 13:06
21
tl;dr: L/D of the airframe and specific fuel consumption of the engines are credible but that doesn't add up to the claims made regarding fuel consumption and speed relative to jets. Laminar flow seems to be used as the snake oil to sell this to gullible customers.
The fuselage shape is inspired by a laminar flow airfoil, like the NACA 64-021 shown below, courtesy Airfoiltools:
NACA 64-021 plot
Now let's have a look how much laminar flow will be possible. Flight speed is claimed to be 205 m/s in maybe 25,000 ft = 7620 m. The Reynolds number per meter in these conditions is 7,314,000. Flat plate flow shows laminar to turbulent transition at about 400,000. With a stabilizing pressure gradient this can be shifted to maybe 4,000,000. So the first 55 cm of fuselage length will exhibit laminar flow but then turbulent transition is unavoidable. I cannot find dimensions for the Celera 500 L, but I think it is fair to say that laminar flow on the fuselage is insignificant. This corroborates well with other aircraft for which a lot of laminar flow had been claimed.
Still, the very clean shape gives it a clear advantage. Add to that high aspect ratio wings with laminar flow, and Otto Aviation's claimed L/D of 22:1 is entirely credible.
Now for the engine: Diesels achieve 220 g/kWh since decades. RED gives 210 g/kWh for the A03, which is again entirely credible. The comparison with turbine engines is complicated by the fact that they define specific fuel consumption per unit of thrust, so we need to look at the engine-propeller combination at 205 m/s. The propeller on the Celera 500 L has five blades and a rather small diameter for take-off rotation and to keep tip speeds subsonic, so its efficiency will maybe be 82%. If we run the A03 at 92% which is its stated maximum continuous power of 338 kW, thrust will be 1352 N and fuel efficiency will be 52.5 kg/kNh which is the same number as what the GEnx-1B64 achieves in cruise. Let's be realistic and double that number for a regular small jet engine (Published numbers are for static conditions and cannot be directly compared. Doubling them for cruise conditions is a good approximation. These numbers are representative of older jet engines and grow by a factor of maybe 1.5 for cruise).
Now we need L/D figures for small business jets. This source doesn't cover jets but shows that small land airplanes with retractable gear still achieve values between 13:1 and 18:1, so even a combination of a 1950's jet engine and an average airframe will only have four to five times the fuel consumption compared to the Celera 500 L. Four, not eight!
For an L/D of <9:1 the comparison airplane needs a fixed gear or floats. With standard design and built any competitor should at least get 13:1 or better.
Sanity check: If the 22:1 L/D can be sustained up to cruise speed, the whole aircraft cannot weigh more than 3033 kg, which is less than half of a King Air 350 which Otto Aviation uses for cabin size comparisons. The King Air, having a smaller cabin and lighter PT6A engines, still needs an MTOW of 6800 kg. Judge for yourself …
Otto Aviation has done everything right, engine choice, propeller position, wing and fuselage layout all support the lowest possible fuel consumption. However, the existing aircraft aren't so poorly made in comparison, either. Also, the installed power looks impossibly low for the claimed cruise speed. In order to fly most efficiently, the Celera 500 L needs to cruise at a much lower speed.
Now for the maximum altitude: No, the Celera 500 L will not reach 50,000 ft. Not even close.
I know a bit about the Strato 2C. It was too heavy for its intended altitude of 65,000 ft. Wing loading needs to be low enough and the engine has to have enough turbo- and/or superchargers to lift its critical altitude high enough. In case of the Strato 2C, it used two turbocharger stages with inter cooling and one supercharger. The intercoolers determined the size of its engine gondolas, which were huge. Given the small air intakes of the Celera 500 L, it looks like it will only reach 25,000 ft or maybe 30,000 until cooling airflow becomes insufficient to keep the intercoolers supplied. Unless Otto straps a rocket booster to its tail, it will never go to even 50,000 ft.
  • $\begingroup$ You mentioned "two A03", doesn't this contraption have only one? $\endgroup$
    – Jpe61
    Aug 30, 2020 at 8:48
    $\begingroup$ @Jpe61 With a single A03 the claimed speeds are completely impossible. And yes, there is only one so I have to rewrite this answer. Your funding hoax opinion looks more and more true. $\endgroup$ Aug 30, 2020 at 15:01
    $\begingroup$ The Long EZ is said to get 30-40 miles per gallon. But slower and much lighter. But they could hook up with Rutan and maybe get some windows on that thing. $\endgroup$ Aug 30, 2020 at 21:20
    $\begingroup$ The Long EZ doesn't get such milage in real life, especially at high speeds. There are one-off examples (Gary Hertzler, Klaus Savier and others) who have tweaked the smaller and lighter Vari-Eze to the max to get as much as 42 MPG but not at 200 MPH, let alone 460. Their efforts and results in the ten CAFE400 air efficiency races are still remarkable. $\endgroup$
    – user31011
    Aug 31, 2020 at 20:29
    $\begingroup$ @ymb1 This is the length after which a Reynolds number of 4 million has been reached and where I assume transition is likely. $\endgroup$ Nov 8, 2021 at 8:59
The following claim was made:
"Otto Aviation explains that the Celera 500L enjoys a 59% reduction in drag when compared to similar-sized airframes." (Source)
I will calculate the Power needed by Celera 500L to fly at 740 km/h assuming its drag is 1-59% that of a Cessna 340, a comparable plane.
Cessna-340 Cessna-340 - Crew: one pilot; Capacity: five passengers: Powerplant: 2 × Continental piston engines, 310 hp (230 kW) each; Maximum speed: 244 kn (281 mph, 452 km/h); Range: 1,406 nmi (1,618 mi, 2,604 km)
For two planes 1 and 2, if 1 has 59% less drag than 2 then the following equations can be written (1=Celera 500L and 2=Cessna 340):
Comparison between Celera 500L and Cessna 340
Regarding the fuel consumption in miles per gallon (see the second part of the calculations above), as the diesel engine of Celera 500L has a SFC = 210 gr/kWh and diesel oil has a density of 0.85 kg/l, it results that, at the speed of 740 km/h (engine power = 1115 HP), Celera 500L has a MPG = 8.47 mi/gal
If we are to believe this statement:
"A 17,000 pound Lear Jet 35, capable of carrying seven people at 485 mph, gets about 4 mpg",
then Celera 500L is about 8.47/4 = 2.11 times more fuel efficient than a Lear Jet 35, not 8 times, and it needs an engine of at least 1115 HP to fly at 740 km/h.
    $\begingroup$ It would have to make around 275 mph indicated to get a TAS in the mid 400 mph range at 8000m. One might wonder as this was the very best a P-51 Mustanger could do with over 3x the rated horsepower. $\endgroup$ Aug 30, 2020 at 14:31
  • $\begingroup$ The lowest drag of an airframe is possible when zero-lift drag is half of total drag. So I propose to double your drag number to account for induced drag and the maximum possible MPG figure in flight is only half of what you use. $\endgroup$ Sep 1, 2020 at 4:48
    $\begingroup$ @PeterKämpf You are right. I have to rewrite my answer to be more explicit. The 487 HP I calculated is the min theoretical power necessary to make a symmetrical revolution body, with a C_D=0.052 and a max cross section = pi*1m^2, travel at 740 km/h through an air with the density=0.52 kg/m3 (8000 m). My C_D is not the Drag Coefficient used in aviation but an ordinary drag coefficient and the body has such a weight as to fall nose down at 740 km/h. There is no lift, only drag. I wanted to show that Celera can not travel through the air at 740 km/h with less than 487 HP no matter what you do. $\endgroup$
    – Simplex11
    Sep 1, 2020 at 5:39
  • $\begingroup$ @PeterKämpf So, basically, Otto Av says Celera has about 59% reduction in drag as compared with a quite similar plane, LearAvia Lear Fan 2100 (see: en.wikipedia.org/wiki/LearAvia_Lear_Fan ), that never entered production but the builders claimed for it a max speed of 720 km/h with a total power of 960 kW. If I apply the formula in the answer above I get Power_Celera = (1-59%) x 960 kW x (740 km/h / 720 km/h)^3 = 573HP. There are two questions here: (1) Are the claimed characteristics of Lear Fan credible? (2) What Otto Aviation did so that it obtained Drag Celera = 41% x Drag Lear Fan? $\endgroup$ Sep 2, 2020 at 17:41
    $\begingroup$ @RobertWerner: This is hard to answer in a comment. The LearFan was a honest attempt to build the most frugal business plane possible but FAA hobbled the carbon fiber design and the gear box kept overheating. But with 2 PT-6 it did reach the claimed speed. Otto will not. So (1) is yes and (2) is most likely not true but pure Marketing. $\endgroup$ Sep 2, 2020 at 17:50
To get in the ballpark, one may look at the Predator, Reaper, Avenger drone evolution. Piston prop, turboprop, fan jet progression for more speed using very efficient high aspect wings.
A useful efficiency comparison metric amoung transportation vehicles is ton mile/gallon. It is important to note 460 mph aircraft (275 mph indicated) weighing 3 tons that get "18 - 25 miles per gallon" simply do not exist. Not even close. This is the most dubious claim. 18-25 ton miles per gallon is more like it.
So how do "gas guzzling jets" do well in this competition? The ability to continue generating thrust at higher altitudes. Piston engines struggle to get enough air and do not generate enough horsepower to effectively turn both the prop fast enough to generate adequate thrust and run the compresser at higher altitudes Adding to their woes is the reduced efficiency of the prop as forward speed increases. Additionally, in thin air, there is little doubt that the tiny Celera prop must go supersonic. A 550 horsepower piston engine doing all that? Not likely. The aircraft in its current configuration may reach 200-250 mph TAS.
Jets shine at higher altitudes in the "tons" and "miles" categories even though they are worse in "gallons", taking advantage of their ability to provide adequate thrust in thinner air.
Much to my surprise, the 450 mph Avenger drone came in at 50 ton mile/gallon, while the slower turbo prop Reaper manages around a fairly typical 25. An improvement on 25 at Reaper airspeeds is what we may expect from the Celera 500L.
Generating enough thrust high will be the challenge with this design, giving them credit for reducing fuselage drag.
Amazingly, compression of an adequate mass of air to generate sufficient power to fly high ... is what jets do best. I would be looking at those drones.
Some more efficiency data to consider: XB 35 flying wing (no fuselage/ contra rotating pusher props) cruise speed: 240 mph ton miles per gallon: 75. B36 Peacemaker (conventional design/ pusher props) cruise speed 230 mph ton miles per gallon: 55. B52 Stratofortress (8 turbojet engines) cruise speed 525 mph ton miles per gallon 40. Boeing 777 airliner (2 high bypass fan jet engines) cruise speed 560 mph ton miles per gallon: 58
U2 spyplane (F104 with very large wings) cruise speed 430 mph ton miles per gallon 46 (a little smaller at 40,000 lbs). Cessna 340 cruise speed 210 mph ton miles per gallon 21 (6000 lbs).
Conclusion: this design may offer improvements in fuel efficiency over similar sized prop driven piston engined aircraft. The major concern would be landing speed and the ability to climb to higher altitudes. However, it may find a commercial niche (manned or unmanned) as a shuttle between large airports with longer runways.
  • $\begingroup$ The rear propeller and the part of the vertical tail placed between the axle of the propeller and the ground (I guess to protect the tips of the blades from hitting the ground during landing and take off) do not seem a good idea for a manned plane. If the vertical tail hits the ground it can be easily damaged and the propeller itself can have the same fate. $\endgroup$ Aug 31, 2020 at 2:38
  • $\begingroup$ The vertical tail issue can be worked around (with longer mains). At 8000 m the very best props make around 40 ton miles per gallon. At 4 tons, they may get around 10 mpg at around 300 mph. They may have scaling issues with their visions, but this is a great experimental project and I wish them luck. $\endgroup$ Aug 31, 2020 at 7:08
    $\begingroup$ A Cessna-340 (1 pilot and 5 passengers), powered by piston engines with 620 HP total power, can not go faster than 452 km/h. In consequence, to reach 740 km/h (the speed of Celera 500), a Cessna-340 would need 620HP*(740/452)^3=2720HP. Celera 500L claims maximum 550HP for 740 km/h!! This is not credible. [Cessna-340 - Crew: one pilot; Capacity: five passengers: Powerplant: 2 × Continental piston engines, 310 hp (230 kW) each; Maximum speed: 244 kn (281 mph, 452 km/h); Range: 1,406 nmi (1,618 mi, 2,604 km). (see:en.wikipedia.org/wiki/Cessna_340)] $\endgroup$ Sep 1, 2020 at 0:38
    $\begingroup$ A 737-400 gets about 32 ton-miles per gallon in best cruise. 436kts 150k pounds(filled up). based on an actual operations manual. These are US short tons(2000 pound) and proper nautical miles. (statute miles haven't been used in legal aircraft specifications, like operators manuals, since the FAA forced better standardization around 1976) $\endgroup$
    – Max Power
    Sep 2, 2020 at 7:28
  • $\begingroup$ Not really significant at cruise, but it would be correct to use CAS not IAS for aero calculations. IAS could hypothetically be any arbitrary number based on equipment calibration, plane configuration, and static air source; but CAS is always just physics. $\endgroup$
    – Max Power
    Sep 2, 2020 at 7:33
