  1. Why is the stalling angle of attack lower in ground effect?
  2. Does ground effect more increase pressure on lower side of wing (cushion effect) or more decrease pressure on upper side, or both? So which side of wing more change pressure in ground effect compare to free flight?
(Please don't explain with terms like downwash, tip vortices, wake vortices etc.. I am big supporter of explaining aerodynamics with pressure/pressure fields rather then "past-things" that happen behind wing.)
  • $\begingroup$ That statement might not be true (or dependent on airfoil) and might in fact be the opposite from this forum thread: pprune.org/tech-log/504142-stalls-ground-effect.html. In particular, the research article mentioned in one of the responses: researchbank.rmit.edu.au/eserv/rmit:6319/Walter.pdf $\endgroup$
    – DKNguyen
    Aug 20, 2020 at 19:43
  • $\begingroup$ It may be more like one can fly at a lower AOA in ground effect (or slower) because ground effect increases the coefficient of lift (by reducing wing tip vortex strength). $\endgroup$ Aug 20, 2020 at 19:58
  • $\begingroup$ You might want to research ground effect vehicles such as the Ekranoplan, since they rely more on the cushion effect, rather than mitigation of downwash. $\endgroup$
    – Raffles
    Aug 20, 2020 at 22:39
Ground effect creates more circulation around an airfoil (either lifting or downforce-ing). Not going into details about how ground effect works, but the 'mirror-vortex' in potential flow explains this very easily.
Increased circulation will manifest in the pressure field as a higher pressure differential between the top and bottom surfaces of the airfoil. An airfoil always has 2 stagnation points, one at the LE and one at the TE. The CP at these points is 1 (the trailing edge stagnation point is lower in real life because of viscous effects). Because the pressure is constrained at the LE and TE, the suction increase happens along the chord, and usually will increase more at the suction peak (~1/4 chord). Now the adverse pressure gradient from the suction peak to the trailing edge is steeper, because we have a higher suction peak, and the same trailing edge pressure. As the adverse pressure gradient becomes steeper and steeper, the airflow will eventually separate from the surface.
Even for the same AOA, ground effect increases the suction on the suction side of the airfoil, which makes the pressure recovery more susceptible to separation.
RE: not using the terms you mentioned, this is a purely 2D effect and can be seen in infinite span wings and has nothing to do with vortices. However just looking at a pressure field without considering anything else is like trying to figure out how a meal is cooked by just looking at the dirty dishes - you need potential flow to explain this.
Regarding what the resultant pressure field looks like, this is very well covered in literature already, and if you want to see the effects for a previously unstudied section, Javafoil will give you useful results - https://www.mh-aerotools.de/airfoils/javafoil.htm
  • $\begingroup$ Unless you are travelling at supersonic speeds, the downstream matters just as much as the upstream. The horseshoe bound vortex from an aircraft's wing that was shed when it was taking off still affects the aircraft (infinitesimally) on landing. $\endgroup$ Aug 21, 2020 at 19:15
  • $\begingroup$ If you fly supersonic, upstream really matters. A large downdraft upstream is still going to affect the aircraft. $\endgroup$ Aug 21, 2020 at 19:29
  • $\begingroup$ nssl.noaa.gov/education/svrwx101/wind/types/…. $\endgroup$ Aug 21, 2020 at 19:40
  • $\begingroup$ Its a weather phenomenon. Don't worry $\endgroup$ Aug 21, 2020 at 19:55
There are 2 effects on wing lift due to proximity to the ground, reduction of wing tip vortex strength, and "cushion effect", both of which will increase the coefficient of lift.
But why a lower stall AOA? Perhaps that which increases the "cushion" weakens the downwash enough for "backflow" to disrupt the upper wing boundary layer at a lower AOA. The encroachment of turbulence (with its buffeting) will occur earlier in ground effect because the lower pressure air "pocket" behind the wing becomes truncated as ground effect increases (for a given AOA and airspeed).
A wind tunnel/smoke study would do wonders to address this issue.
