According to Cessna 172 POH the speed for max range with power off, or glide speed, is 65, and achieved at the best L/D ratio. However with power on the speed for max range will be around 75. Why is there a difference between speeds for max range with and without power?
Edit- Is this because with power off we are just looking for the lowest point on the drag curve, and with power on we are willing to accept the increase in drag from speed of 65 to 75 since I guess lift increases more then drag between those speeds?
