I am referring to a Boeing 737NG. Assuming I am on a VNAV climb but I am instructed by ATC to climb only to an altitude lower than my FMC Cruise altitude. After leveling off, how do I resume my VNAV climb to my FMC Cruise altitude after I am cleared by ATC to do so? I obviously have to set my FMC Cruise altitude in the MCP Altitude window, but as VNAV is already engaged from before ans is the active mode, will the aircraft start climbing automatically, or do I have to disengage and re-engage VNAV by pushing the VNAV button OFF and ON again? Or, alternatively, do I have to press the ALT INTV button to resume the VNAV climb to my FMC Cruise altitude?
    $\begingroup$ Turn off autopilot, push thrust lever forward, pull back on yoke, at FL410 turn on autopilot. $\endgroup$
    – Max Power
    Sep 2, 2020 at 11:06
So your CRZ page shows your cruise altitude as FL 410, but you've leveled off at FL370, which is what's in your MCP Altitude window. Now ATC clears you to climb to 410.
You set 41,000' into the MCP Altitude window. At this point, your FMA vertical mode changes from VNAV to Altitude Hold. The light in the Alt Hold button is on, and the light in the VNAV button is not. To initiate the climb, press the VNAV button, and observe the FMA change from ALT HOLD to VNAV Speed. At this point, the autothrottles advance the power, the autopilot increases the pitch to maintain your FMC-computed airspeed, and you're climbing again.
The key is that when you initially leveled off at FL370, the FMA stayed in VNAV Speed, but as soon as you changed the MCP Altitude, the FMA changed to Altitude Hold. Thus, one tap on the VNAV button re-engages VNAV & you resume the climb.
Side note: why doesn't the FMA change immediately to Alt Hold when you level off at 370? While Boeing may have another answer, my best explanation is that if you change your cruise altitude in the FMC from FL 410 to FL 370 after you leveled at 370, you stay in VNAV, and the FMA just swaps from VNAV Speed (i.e. the climb mode) to VNAV Path (i.e. level-at-cruise-altitude mode). So at the intermediate level-off, it stays in VNAV, waiting to see if you'll reset the MCP altitude (to continue the climb) or if you'll reset the FMC cruise altitude (to make this your cruise altitude). In the former case, the VNAV button starts the climb; in that latter case, no MCP buttons need pressing.
Added:
The case where Altitude Intervention will start your climb is different: in that case, you're AT your FMC cruise altitude, either because you climbed there directly, or else you leveled off at an intermediate altitude and then changed your FMC cruise altitude to match. The latter is NOT common practice, but there are scenarios where it could happen.
Either way, you're at cruise in VNAV Path. Now ATC clears you higher. So you set the new, higher altitude in the MCP altitude window. At this point, the FMA still displays VNAV Path. Press Altitude Intervention, and that changes the FMC cruise altitude to what's in the MCP. With VNAV (still) engaged and your altitude below both the MCP altitude and the FMC cruise altitude, you'll get a climb.
The difference in these two cases is being at, or not being at, the FMC cruise altitude. In the case discussed first, you're below it. In the second case, you're at the cruise altitude. In the first case, Altitude Intervention won't help you (because you're in ALT HOLD and not VNAV); pressing VNAV will. In the second case, you're in VNAV, so pressing that button won't help you; resetting the FMC Cruise Altitude (either by entering it in the FMC via the CDU, or by pressing ALT INTV) will.
This stuff is complicated, and the manual doesn't generally do a great job walking through every scenario and "what if". After you've seen it in the jet (or a simulator with good fidelity) a few (dozen) times, it makes much better sense.
I'm not aware of any 737 setup where anything varies varies from what I've discussed above, although if the Smiths FMC is replaced by something else, all bets are off. There are some things that vary from one aircraft to the next (geometric path descent vs idle descent logic being one -- it's selectable by the airline), but nothing here, as far as I know, is in that category.
As far as simulators go, I can't speak to which ones have fidelity to what goes on in the real aircraft or not. (The ones I train in are extremely accurate that way, but they're not running on a PC!)
It seems that there are varying software and it all depends on the specific FMC/MCP hardware installed. See below: MCP Altitude Intervention
MCP Altitude Intervention (2)ps://i.stack.imgur.com/iB5Bp.jpg
    $\begingroup$ The Alt Intv function addressed at the red bracket works when you are AT your FMC Cruise altitude & you've dialed a higher altitude into the MCP. That isn't the scenario the OP asked about. Also, nothing on these pages supports the "varying software/specific hardware" statement with regard to anything in the OP's question. $\endgroup$
    – Ralph J
    Aug 11, 2020 at 15:25
    $\begingroup$ Oh, wait, you ARE the OP. In your original question, you leveled off BELOW the FMC cruise altitude, yes? And didn't change the cruise altitude to match, presumably. (You'd affect fuel predictions if you did that.) In that case, Altitude Intervention won't help you. $\endgroup$
    – Ralph J
    Aug 11, 2020 at 15:30
  • $\begingroup$ Also, nothing on these pages supports the "varying software/specific hardware" In the first answer, dialing a higher altitude the MCP switches from VNAV to ALT HOLD. In the other case, no mention of ALT HOLD is mentioned. In the first answer, you resume climb by re-engaging VNAV. In the manual I posted above, you resume climb by pressing ALT INTV. Or have I got it wrong? (quite possible :-) ) $\endgroup$ Aug 11, 2020 at 16:24
    $\begingroup$ I've added an explanation to my answer to address how the system works. The manual posted is entirely consistent with what I'm describing, but there are two different scenarios -- one needs VNAV, the other needs the FMC Cruise Altitude changed (via ALT INTV or otherwise). $\endgroup$
    – Ralph J
    Aug 11, 2020 at 23:14
