Are there any regulatory release documents applicable to Medical Kits and Defibrillators? Question is for Commercial Airlines.
For example for:
  1. Components, you are required to have an EASA Form 1 or FAA 8130-3 release tag.
  2. Standard Parts, you can accept with a CoC (Certificate of Conformity/Conformance).
What are similar standards for Emergency/Medical Equipment?
  • $\begingroup$ I think this depends on what type of operation you are. If you are going part 91, there isn't one. I also don't think there is one for commercial operations less than 10 or 12 passengers. $\endgroup$ – Ron Beyer Aug 6 '20 at 11:40
  • $\begingroup$ Thanks for the comment, it made me realise I should have clarified my question is for commercial airlines. $\endgroup$ – Kamran Aug 6 '20 at 11:49
    $\begingroup$ Again ‘commercial’ is a relative term and can apply to the Part 91 ops that Ron Breyer described as well. You’re probably thinking of scheduled air carrier operations under Part 121. $\endgroup$ – Carlo Felicione Aug 6 '20 at 12:10
  • $\begingroup$ Yes I'm talking about scheduled carriers such as BA, Lufthansa, Emirates, etc $\endgroup$ – Kamran Aug 6 '20 at 12:18
  • $\begingroup$ You tagged both [faa-regulations] and [easa-regulations]. None of the 3 airlines you mentioned fly under Part 121 [faa-regulations]. Only BA and Lufthansa fly under [easa-regulations]. Could you clarify what country/region you want to know about? $\endgroup$ – Bianfable Aug 6 '20 at 12:25
I can’t comment on ICAO requirements, but for domestic and Flag Operations in the US, §121.801 - §121.805 and §121 Appendix A cover the requirements for emergency medical equipment, including electronic defibrillators, to be onboard scheduled air carrier aircraft and specify training requirements for flight crew members on their use.
  • $\begingroup$ Hi Carlo, indeed the requirement for having these onboard exists but I was wondering about any specific airworthiness or CoC document requirements? Or can such equipment and kits be carried without any such documents? $\endgroup$ – Kamran Aug 6 '20 at 12:46
