I am wondering how the ground speed of hot air balloons is controlled. The wind is obviously going to have a large influence upon the ground speed, but apart from wind effects, do hot air balloons have the ability to control their ground speed? If so, how? Is there a maximum limit to the ground speed of a hot air balloon? What factors contribute to this speed limit?
  • 8
    $\begingroup$ The wind doesn't just "have a large influence", it is the one and only determining factor. $\endgroup$ Aug 2, 2020 at 10:37
  • $\begingroup$ Wow, 4 answers to chose from. I would have accepted @expeditedescent's comment. $\endgroup$ Aug 3, 2020 at 3:35
    $\begingroup$ Voting to reopen. The "duplicate" question is certainly related, but the answers there do not, in fact, answer this question, which is much more basic and fundamental. $\endgroup$ Aug 3, 2020 at 16:21
5 Answers 5
10
Balloons travel with the wind, so all their motion over ground comes from air movements.
This was a burning question in the nineteenth century and many attempts were made to influence ground speed, apart from rising into higher altitudes and testing whether the wind direction there is different. Naive people added sails but had to notice that those remained limp and only added weight. Others added paddles or engines (steam, electric and gasoline engines were tried) but success was limited before Zeppelins started to make directed lighter-than-air travel routine.
An interesting variety was tried by the Swedish balloonist Salomon August Andrée who added three long ropes to his balloon, their ends dragging on the ground. This caused drag which slowed the balloon, thus giving it some speed difference versus the wind. Now, with some relative wind, sails could indeed generate a force which could move the balloon sideways. However, when tried in 1897, two of the ropes were lost during launch and the remaining one proved ineffective.
Andrée's balloon
Andrèe's balloon (picture source)
No, if the balloon rises into the jet stream, it can travel at several hundred miles per hour. There is no speed limit once the balloon is up in the air.
However, filling and launching the balloon requires calm winds; hot air balloons almost never start in winds higher than 10 miler per hour. Landing in higher winds becomes dangerous, so here also a calm wind is preferred.
This is not about ground speed limits, but wind speed limits: While there is no fixed limit, higher winds will prevent the envelope to stretch out completely and rise up when being prepared for launch. Instead, the windward side will remain dented. During landing, the gondola will be dragged along on the ground when wind is too high. Both these factors let balloonists prefer calmer wind for take-off and landing. Once the balloon is up in the air, no such limit exists any more.
A hot air balloon has no means of (horizontal) propulsion. As such, it will not move relative to the surrounding medium (the air). If the air moves relative to the ground (wind), the balloon will remain stationary relative to the air, and thus also move over the ground.
In other words, if the wind is blowing at 10 knots, the balloon will have a ground speed of 10 knots. If the wind is blowing at 200 knots, the balloon will have a ground speed of 200 knots. Regardless, from the perspective of the balloon, it will be stationary (relative to the air).
An ordinary hot-air balloon drifts with the wind and so its ground speed is always that of the wind.
Some control over flight direction is possible by knowing or guessing the wind direction at different altitudes and climbing or descending to a level where the wind is favourable.
A hot-air "dirigible balloon" or airship has an engine and propeller. But they have been few and far between, I don't know if any are still flying.
  • $\begingroup$ How does the balloonist know the wind direction at different altitudes in advance? $\endgroup$
    – Flux
    Aug 3, 2020 at 2:17
  • $\begingroup$ Specialist weather forecasts are often available. As you go up through the levels, you take note. Clouds or birds at different heights sometimes give clues. Experience of wind conditions and knowledge of meteorology also help, But it is far from an exact science. On a competition flight, the unlucky or less skilled competitors may end up way off target. $\endgroup$ Aug 3, 2020 at 5:38
pretty much answered that we go the speed of the wind but I dont think it was mentioned that air speed can vary by altitude not just direction but also speed. you may have higher winds on the ground and come to a complete stop higher up. or there may be a fast layer. and as such you can punch through that layer and not allow yourself to completely get up to the speed of that layer. balloons are several thousand pounds of mass, essentially weigh more than most cars. it takes a while for the air to change the direction of that mass. The basket can be in a different layer than the equator and you will feel that wind on your face or body as the larger part of the envelope has the most drag and really determines the speed.
with experience you can punch down into a fast layer on the ground and land before completely getting up to that speed. at the same time depending on what and where you are landing a long drag on the ground is okay. Also depending on your balloon and experience you can dump the air out, esp on higher wind landings very fast, top fully open or a cap top that is fully open as the balloon tips over that ball of heat mostly exits the balloon.
You can also do things like rub the ground or rub trees to slow down but this has its own experience and risks involved, generally not something you do.
but as everyone has answered, most of the time, you are going at the speed and direction of the wind that is around the balloon.
The only horizontal forces which act on hot air ballons are that of drag because of wind. In other words, balloons are pushed around only by wind. There is no other horizontal force (e.g. motor, or other means of propulsion) which act upon the balloon. This means that as soon as the balloon reaches the wind velocity, it will not feel any other horizontal force. If it slows down/speeds up for some reason, the wind will push it again until it reaches the wind speed.
Therefore: The ground speed of the balloon is always that of the wind.
As a side note: Balloons exploit the fact that at different altitudes the wind blows in different directions and at different strengths. By flying at different altitudes, the ballon can use the different directions of the wind to reach its destination.
