When doing a hold in leu of a procedure turn are you required to do a full hold for the course reversal or just the entry to the Fix and then proceeding in bound for the final approach course?
$\begingroup$ Welcome to aviation.SE! Are you asking about US/FAA procedures? For questions about regulations, procedures etc. please always tell us which country or regulations you're interested in. $\endgroup$ – Pondlife Jul 28 '20 at 17:03
No, you're not required to do a full oval-pattern hold. Once you're tracking the inbound course immediately after the entry maneuver (teardrop or parallel) and pass the holding fix, you're done and can proceed inbound on the approach.
Either the teardrop, or parallel entry turn-around is adequate and then once you cross the fix upon which the hold is based, you may continue straight inbound on the remainder of the procedure.
Of course, any ATC instructions to remain in a holding pattern override this default.
When performing a HILPT, typically the aircraft will pass the hold point outbound and perform the correct entry. When you are inbound, you will continue with the approach once crossing the hold point again.
The aircraft will only pass the hold point twice unless a request is made to ATC for further hold to get ready to fly the approach.
