12
I've flown a few times in my life, both in economy and executive class. Every time I fly in executive, during takeoff, there is a different noise from the engines. In economy class (behind the engines) the wind sound dominates, but in the executive class you hear the noise in the video below until you're high in the skies. Why is that?
  • $\begingroup$ Behind the engines is also behind the wing. The wing disrupts airflow (the wind noise). Behind the engines much of the engine noise is muffled by the wing and engine cowl. $\endgroup$ Aug 3, 2014 at 1:52
  • $\begingroup$ Related: Why do most A320s make that distinct scream on takeoff? $\endgroup$
    – fooot
    Jul 2, 2015 at 14:39
13
That buzzing sound is from the tips of the fan blades breaking the sound barrier. When you're sitting farther back in the airplane, that sound is overpowered by the sound of the exhaust, which is the roaring part of a jet engine's sound.
So in general, sit forward of the wing, you'll hear the fan sound (the buzz), sit aft of the wing and you'll hear the exhaust sound (roar). It'll vary from airplane to airplane of course, and when thrust is reduced and the fan speed slows, the buzz will subside.
  • $\begingroup$ Do you know why the engine suddenly changes sound at 1:45 ? $\endgroup$
    – rebellion
    Aug 30, 2016 at 17:46
    $\begingroup$ Thrust was reduced there. $\endgroup$
    – Khantahr
    Aug 30, 2016 at 18:07
  • $\begingroup$ I notice that sound every time I fly, and I always thought it was either the thrust that was reduced or it was the air pressure/clouds that changed the sound of the engine. Thanks Ralgha! $\endgroup$
    – rebellion
    Aug 30, 2016 at 20:22
