How can multiple owners save on the cost of a plane that sits 1-4 people. If each nonprofessional person contributes equally in money, how would it contracted up to share all the costs are divided fairly. With at least 1 pilot and 1 A&P mechanic to contribute in labor, how many others could "time-share" on one plane before it too much to be worth it? Is there a method or scheme cost efficient and fair?
2$\begingroup$ what you describe could be called a flying club or shared ownership. These sorts of arrangements are common enough that you should be able to find a template for setting up one which contains the details of how maintenance and overhead are covered and how the club's finances must be recorded and reported. The cost effectiveness and fairness are determined by how money flows into the partnership and how it flows out. I would suggest you look into the Experimental Airplane Association's documentation on airplane ownership. $\endgroup$– niels nielsenJul 24, 2020 at 1:49
1$\begingroup$ @nielsnielsen you should drag the comment right into an answer. I am so new and I want to make sure I do it right and cheaply per person. I will check those out. TKS $\endgroup$– JustintimeforfunJul 24, 2020 at 1:52
$\begingroup$ "worth it" is something only you can decide, for some the luxury of never being blocked on a schedule makes solo ownership "worth it". Most clubs have an hourly rate based on operational cost, fixed costs, and engine reserves where mechanics/A&P's "buy" time with labor hours. I have seen clubs with 5 members and one plane and clubs with 200 members and 5 planes. $\endgroup$– DaveJul 24, 2020 at 2:06
$\begingroup$ AOPA has a great guide to starting a flying club, and another one on shared ownership. I hope that helps! This is a great question but resources come and go, so I'm not posting this as an answer. $\endgroup$– PondlifeJul 24, 2020 at 2:36
$\begingroup$ Most flying clubs consist of all pilots. The fact that you mentioned possibly just one pilot and "non-professional others" as co-owners in the manner you did leads me to believe you are more interested in some sort of aero-limousine arrangement. Are you a pilot? If not, would you please clarify your intent? Because what you are describing sounds more like private carriage, which operates under some different rules... $\endgroup$– Michael HallJul 24, 2020 at 3:10
I've been in a couple of partnership syndicates, including one that owned 3 Cessna 180s on floats, that was set up as a limited liability corporation with 15 equity members as shareholders, and more or less operated like a private flying club.
However, the sweet spot for a single airplane partnership is no more than 2-3 owners. Any more, and the potential interpersonal issues and the fact that you are creating a "flying club" are not worth the minor additional dilution of fixed costs going from 3 owners to 4 or more.
A lot of partnerships go sour, and the problem becomes how to sell an individual share in an airplane that the other partners may want to keep, and who don't want to buy you out. You have to find a buyer who is willing, and the buyer has to be approved by the other two partners. That can be tough.
It's best done with a written co-ownership agreement that lays out everything in writing to minimize disputes, such as how and who does maintenance, hourly rate to be charged, booking policy, and various rules. Of course you need to have full in-motion hull insurance to protect everybody's equity. Even a two-partner operation should really be run like a mini flying club to keep it going smoothly.
It's also better for the 3 owners to have the maintenance done by a 3rd party, with the partners just paying out equal shares of cash for whatever comes up. If one of the partners does significant work on the plane, it can create problems with uncompensated work leading to resentment, plus you get disagreements between the partners on what or how things should be done (this happened to a friend that was in an RV-6 threesome and did all the maint - he was secretly relieved when another partner wrote it off when he flipped it (unhurt) and he was cashed out on the hull insurance). Better to just give it to a mechanic and share the bill.
It can work quite well, because most owners only fly a few dozen hours a year, not enough to justify bearing all the fixed costs, and splitting ownership 2 or 3 ways has little practical impact on availability, but be careful. Some friends own 1/5th shares in a pristine Aeronca Champ, and it seems to work ok, and the cost dilution makes it pretty affordable, with each owner only having about 4K in equity, a thousand dollar annual split 5 ways, and a 65 horse engine that only burns 4 GPH.
$\begingroup$ I would disagree a bit. Was in a 4-way partnership for years, with not many problems. Didn't have major problems selling shares - I bought into the existing partnership, and a couple of members sold theirs during my time. WRT maintenance, it very much depends on the individuals. I wound up doing most of it, but that was because I enjoyed it. $\endgroup$– jamesqfJul 24, 2020 at 3:40
$\begingroup$ Depends a lot on the local market and the type of a/c when it comes to sale ability of shares. The interpersonal compatibility of the partners is really key, but you don't really know if that's going to work until you try it. The 15 partner syndicate I was in worked fine, but that was mainly because there was someone who took on the job of running it willingly. $\endgroup$– John KJul 24, 2020 at 4:05
