I know that companies such as Lockheed Martin and Boeing design and build planes for the US Air Force. However, when I was thinking about this, I realized the Air force has no part in designing the thousands of aircraft they own (or am I wrong). Does the Air force basically act as a consumer or do they help in the process of designing the jets? (I know there is a job of an aircraft mechanic but they act as maintenance people and don't design the jet.)
5$\begingroup$ Perhaps some useful language is that the A.F. "directs" the entire process. The AF doesn't sit down and use Photoshop to make a jpeg to send to a supplier in China to fabricate a hinge or fan blade, but the A.F. "specifies" or "directs" the whole show. $\endgroup$– FattieJul 18, 2020 at 11:29
While the Air Force (or other military unit) does not design their own jets, they do release specifications and have contests (e.g. the ATF that selected the F-22). This is basically the way it works (and not just for fighter procurement):
- A design specification is released, these include things like range, mission, weapons.
- A "paper" design is submitted from companies like Boeing and Lockheed Martin. These may be based off of existing designs or "clean sheet" designs.
- The military funds the development of one or two prototype aircraft from a number of paper designs.
- The military evaluates each design against the specification and selects a "winner".
- A larger contract is awarded
So it's not really up to companies like Boeing or Lockheed Martin to come up with their own designs and sell that to the military. They work under strict program requirements to develop something "to spec" and then demonstrate the capability. The military has a hand in the design process as this goes along, so they are not entirely "out of the loop".
The secondary market is different though. Boeing may sell (with the approval of the US Government) these aircraft to certain foreign military groups. These work more like selecting something from available stock in the dealer lot.
3$\begingroup$ This has changed over the years. There's an anecdote that the specification of the original Hercules fit on a single page; by the time the C-17 rolled around, its spec was so extensive it filled up a Herc's cargo bay. $\endgroup$– HobbesJul 18, 2020 at 8:09
10$\begingroup$ @Hobbes I think that's a joke, not an anecdote. ;) $\endgroup$– J...Jul 18, 2020 at 11:28
5$\begingroup$ I propose to add a point on top of the list mentioning that military planners study political, technical and social developments and come up with scenarios for future conflicts. From that, they derive what follows in the first point of your list. This is substantial and very influential work because here the path the design will take is determined. $\endgroup$ Jul 18, 2020 at 11:44
6$\begingroup$ @PeterKämpf A very valid point. Studies by Defense Acquisition University have shown that decisions in the first 6 to 12 months of a program will drive 80% of the life cycle costs of the program. The next 10 years or so is just working out the details. The military is concerned about what it does. The contractor has to work out the how. But much of an aircraft is mature technology. The 'new' tech that provide the unique capabilities is a constant discussion between the military and the contractor. It not only has to perform as desired, it has to be sustainable. $\endgroup$– GerryJul 18, 2020 at 12:25
$\begingroup$ @PeterKämpf That's one theory of how the political process might go, but in reality there are other just as valid theories (which I personally think have more merit). For an aviation site, the starting point of this answer is completely appropriate. $\endgroup$– NobodyJul 18, 2020 at 16:07
The answer to your question largely depends on your definition of "design", as well as the specifics of the procurement program.
In general, the Department of Defense (DOD) does not have engineering authority over the equipment it procures. That is, Pentagon employees do not produce and sign engineering drawings for hardware built by contractors. However, almost all such data is reviewed by the DOD in detail before being implemented.
More broadly, though, the final configuration of a military aircraft is the result of a continuous back-and-forth between the supplier and the DOD. In my experience, this interface occasionally borders on collaboration. Sometimes a Pentagon requirement is broad and it is expected that the contractor use its expertise to come up with a creative implementation independently. Sometimes the DOD uses a so-called "directed solution", which tells the contractor almost exactly what the final product should look like in practice. And everything in between.
Your parenthetical actually illustrates a very important example. I spent years working on teams tasked with figuring out how to design military aircraft to be as friendly as possible to the mechanics and maintainers. Without the input of DOD mechanics in the field, we could not have done our job well, and the final design of the systems was certainly different than it would have been without that input.
2$\begingroup$ This is the correct answer, the question simply depends on your definition of "design". $\endgroup$– FattieJul 18, 2020 at 11:28
$\begingroup$ @Peter Schilling What company did you work for? $\endgroup$ Jul 21, 2020 at 22:46
I suppose this depends largely on how broadly you define "help design." If you're limiting the scope to an actual aircraft design project, the other answers cover that well: the USAF determines what it needs, Congress changes it to something that brings business to their districts and approves funding for it, and then the USAF issues detailed requests for proposals from the likes of Boeing, Lockheed Martin, Northrop Grumman, etc.
However, the Air Force does do a ton of research that develops a lot of the technologies that will eventually be included in those airplanes. It also does a ton of verification testing, as well as overseeing development contracts. This is pretty much the entire mission of the Air Force Materiel Command, which employs approximately 80,000 people. AFMC is the most-funded major command within the Air Force, representing 31% of USAF outlays, according to Wikipedia.
The Air Force Research Laboratory oversees early-stage research projects, as well as conducting a good deal of its own research that will eventually end up in USAF hardware, though it typically doesn't design or produce the actual production hardware itself.
Bases like Eglin, Edwards, Arnold, Holloman, and others perform aerodynamics testing and flight testing for experimental aircraft as well as for production aircraft and engines for all branches of the military. For example, Arnold conducts most of the wind tunnel testing for U.S. military aviation, as well as testing jet engines, rocket motors, and space vehicles. While their mission is primarily military, they also do a lot of contract testing for civilian projects, including commercial projects as well as NASA projects. There's a good chance that the engine powering your airliner was tested there at some point during its development.
So, if your definition of "help design" includes conducting a lot of the early research that ultimately makes the production technologies possible and design verification testing (including flight testing, wind tunnel testing, engine testing, etc.,) then, yes, the USAF does participate quite heavily in developing its aircraft. However, if you're excluding these activities and also excluding developing the detailed requests for proposals, overseeing the bidding, overseeing the development efforts of the winning bidder, etc., then you could argue that it doesn't "help design" them to a large extent. The latter would seem to be a short-sighted view of what "help design" means in my personal opinion as an engineer, though.
$\begingroup$ Thanks! Did you work for any of the companies stated above? $\endgroup$ Jul 21, 2020 at 0:06
3$\begingroup$ @LukeJustin No, but I worked for the Aerospace Testing Alliance at Arnold AFB. $\endgroup$– reirabJul 21, 2020 at 1:23
$\begingroup$ Did you test any types of planes or jet engines. Did you see any planes before they were released to the public? $\endgroup$ Jul 21, 2020 at 12:37
1$\begingroup$ @LukeJustin I wasn't testing them personally, unfortunately. I was just there for a few months on a summer engineering internship during college. I did see some of the tests in progress, but I wouldn't be allowed to talk about exactly what (it was a USAF base, after all.) $\endgroup$– reirabJul 21, 2020 at 23:30
In short: the US Air Force does not do any design work, primarily because they have deliberately decided not to maintain the necessary expertise. Other DoD entities do, to a greater or lesser extent. This has been true for the past couple decades, but was not true historically.
As other answers have stated though, a detailed answer depends what you consider "design," "aircraft," "does," and "help" to mean.
"Aircraft" is probably the easiest: it is fairly common to require specific systems be put on a platform. For example, you might see a requirement for a specific IFF transponder (or the prime contractor might select a specific IFF transponder), which might be provided as Government Furnished Equipment (GFE - essentially the government is supplying their own parts to be installed). That box is then part of the design of the aircraft, and the prime contractor is relying on the government to ensure it works as required. Small avionics boxes like that are more likely to have more design influence from the government side. So, if exerting design influence on that box counts as exerting design influence on the "aircraft," then the USAF does do design work. It is overwhelmingly common to have a random assortment of configuration items (especially avionics) provided as GFE, usually as a misguided attempt to save money.
"Does" is next. The USAF got out of the design business. I am not aware of any specific policy decision that drove this, but anecdotally it seems to have happened in the '90s. Before that, it was much more hit or miss. E.g. the SR-71 was built based on a half-page of requirements while Lockheed stiff-armed the USAF away from any design insight, But John Boyd famously drove the overall capability requirement for lightweight fighters and exerted tremendous design influence on the F-15.
"Design" and "helps" are a bit sticky. At a 50,000 foot view, the idealized modern US acquisition process goes something like this: combatant commanders (the heads of CENTCOM, PACOM, etc.) plan constantly for campaigns they might need to execute. As part of that, they note gaps in the capabilities available. E.g. maybe PACOM is concerned about pirates, and wants a capability to conduct small boat boarding operations from fast-mover aircraft. That capability need gets rounded with all the others and sent up to the Pentagon, where the Joint Requirements Oversight Council figures out how to address it (see: DOTMILPF), and racks-and-stacks it into a package of capabilities. If that package has a materiel component (i.e. if you need to buy stuff, not just re-train or whatever), it goes into the budget request and gets money allocated to it. Then the money and capability requirements go to one of the acquisition commands (AF Materiel Command, IIRC), which takes that crazy wishlist, turns it into a specification (usually. USAF does much less specifying than other branches), and goes and buys the thing specified. As part of the "goes and buys" process, the government usually takes control of various design elements after they are complete. The degree of control and degree of insight the government has varies wildly from program to program, but the AF tends to rely on prime contractors much more than the other services. Finally for any major weapon system and many other systems, there is an "operational evaluation," where real users really test it out to see that it meets the capability needs that JROC described. The feedback from that might well influence design.
