Most E-M diagrams for high-performance aircraft show a "dog house" plot with turn rate on the Y axis and velocity on the x axis. They may also have additional lines for constant turn radius and load factor. There are also Ps curves that show specific excess power at an given point in the performance envelope. The Ps curves tend to be shaped like a "rainbow" when superimposed on this chart. Most curves that I've found only demonstrate performance at maximum thrust (normally maximum afterburner). However, I'm curious what the Ps curves would look like at 100%, 75%, 50% power, etc. I theorize that the Ps curves would tend to become flatter and would shift to the left of the chart. Ideally, I'd like to see a comparison of two charts at different (known) throttle settings (with all other parameters being equal).
$\begingroup$ Why would curves for less than mil power be interesting in any way? $\endgroup$ – Ralph J Jul 16 '20 at 4:21
$\begingroup$ The greater power need to hold the velocity in the turn, the less excess power you have. A tighter turn will be draggier. The curves at lower power levels will look the same as max power for progressively smaller engines, all the way down to hamster wheel. $\endgroup$ – Robert DiGiovanni Jul 16 '20 at 14:24
The shape does not change much, but they shift up and down. Below you see a diagram I once made for a HALE unmanned airplane with a turbofan engine. Instead of varying thrust I calculated the instationary turn rate at different sink speeds. Sinking frees up energy similar to a thrust increase, so these curves should look the same for different thrust levels. After all, the unit for SEP is a speed, too.
Turn rate diagram for different sink speeds and flap settings. Blue lines are for cruise and red curves for the landing setting of a simple camber flap. The aerodynamic model did not include wave drag, so the results above Mach 0.7 are not correct.
As you rightly assumed, the curves shift to lower speeds for lower thrust, but only the red ones become flatter for lower sink speeds / thrust levels.
