What is considered to be an "unstable approach"? Which are the exact parameters against which an approach is being judged, in order to be considered "stable" or "unstable"?
$\begingroup$ Does this question help? $\endgroup$– PondlifeJul 15, 2020 at 21:49
$\begingroup$ The exact criteria varies amongst aircraft type and even from airline to airline. $\endgroup$– BenJul 15, 2020 at 22:14
6$\begingroup$ Does this answer your question? What is a stabilized approach? $\endgroup$– Aaron HolmesJul 15, 2020 at 22:29
$\begingroup$ For visual landings, when you gain experience and skill, the need for a "stable" approach all the way down to be able to land safely becomes somewhat less important, as long as you can get yourself configured properly in the last couple hundred feet. When you get to that "at one with the plane" level of skill, that can be fairly easy to do. $\endgroup$– John KJul 16, 2020 at 0:22
