Been thinking of getting into the hobby of building ultralight helicopters, and would PVC tubing be a good choice to build the overall airframe?
No. The strength to weight ratio of PVC is poor compared to aluminum and you would end up with a very heavy, albeit cheap, machine, and will be even worse when compared to carbon fibre tubing, which would be the optimal choice performance-wise. Extruded aluminum tubing would likely be the best choice cost wise. Forget about building a plumb-O-copter.
| improve this answer | |
  • $\begingroup$ If you're talking about the sort of PVC tubing used for irrigation systems, not only is it not very strong, it's also quite flexible. Hold a 10-ft length (standard size in US hardware stores) in the middle, and it will deflect at least 6" on either end. $\endgroup$ – jamesqf Jul 10 at 3:23
  • $\begingroup$ I think he has in mind Sched 40 or Sched 80 rigid plumbing pipe. $\endgroup$ – John K Jul 10 at 11:55
  • $\begingroup$ If I'm not mistaken (I'm no expert), schedule 40 PVC is the white pipe commonly used for irrigation &c. $\endgroup$ – jamesqf Jul 11 at 5:19
  • $\begingroup$ Sched 40 is the standard PVC for residential house plumbing, good for a 2 or 3 hundred psi burst. Schedule 80 is for higher pressure applications and has nearly double the wall thickness (smaller ID). $\endgroup$ – John K Jul 14 at 20:00
  • $\begingroup$ Sure, but bursting strength is not really what's important in building airframes :-) $\endgroup$ – jamesqf Jul 15 at 21:05
In my experience using PVC to build scale models, PVC doesn't make a good construction material:
  1. it's too flexible. PVC pipe will bend under its own weight.
  2. the glue typically used to join PVC is pretty weak, impact loads will break the bond.
PVC is no where near stiff enough for a given weight. And its strength to weight ratio is poor. The structural efficiency of air machines is absolutely critical otherwise you are building a machine that may not fly at all.
Plus, do a search for helicopter ground resonance, especially watch some youtube videos of helicopters destroying themselves.
