I'm trying to figure out typical AR values for a T-tail configuration (at the conseptual design phase). Working with Raymer I found this table:
I can see the typical AR values for the vertical tail but I cant find anything about the horizontal one. The only info that I got is that it should be lower than wing's AR. The aircraft that I'm interested about is a twin turboprop.
  • $\begingroup$ I'm not sure if JAWA has tail-aspect ratios. You could also find planform images of the aircraft you have in mind and calculate the aspect ratios. Here's a list of T-tail aircraft $\endgroup$
    – pho
    Jul 2, 2020 at 18:11
Hmmmm.
enter image description here [Source] enter image description here
ATR42=6:1
Dash8Q400=4:1
I'm not aware of any reason why the aspect ratio of the horizontal stabilizer of a T-tail needs to be any different than that of a conventional tail. I always interpreted the dash in Raymer to mean that the h-stab should be sized similarly in T-Tail as in a conventional. Apparently this source shares my interpretation.
Due to the end-plating effect, the vertical tail in a T-tail is more aerodynamically effective, resulting in generally shorter v-stab. However, for the same surface area, T-tail would have a heavier structure to cater for uneven load cases on the h-stab and the need for a bullet fairing.
