I'd like to fly around Mount Rainier in a C172 out of Renton (KRNT). What route do people usually take? I wonder if I can climb quickly enough once out of Seattle class B airspace for terrain around Mt Rainier. What do people usually do?
    $\begingroup$ At what altitude are you wanting to fly around it? Do you have mountain flying experience? $\endgroup$
    – Ron Beyer
    Jun 24, 2020 at 19:08
  • $\begingroup$ Only a little bit of mountain flying training in New Zealand.. at 10,000 $\endgroup$
    – Shaun
    Jun 24, 2020 at 19:34
    $\begingroup$ If you don't get a good answer here you might try a discussion board or the FATPNW Facebook group. I suspect there may be different opinions on this. $\endgroup$
    – Pondlife
    Jun 24, 2020 at 21:10
I fly out of BFI and RNT. The short answer is go East to clear the B, then South to parallel terrain as you climb. You will have more time to do this if there is a North flow.
There’s no specific route per se, just climb as best you can while keeping between the two.
The Lake Youngs departure gets you going in the right direction, and once just past Enumclaw you can make a circling climb to get comfortably above the ridges.
