For airfoils in unsteady motion, the lift coefficient oscillates and the wake is characterized by vortex shedding.
How does vortex shedding affect the lift coefficient for an airfoil?
Sign up to join this communityFor airfoils in unsteady motion, the lift coefficient oscillates and the wake is characterized by vortex shedding.
Shed vortices from unsteady flow over an airfoil result in decrease and phase lag in lift.
Using thin airfoil theory in incompressible flow, the lift coefficient for an airfoil undergoing cyclical pitching and/or heaving can be expressed as (Ref. Drela, Flight Vehicle Aerodynamics):
$$C_l=\text{Re}\{ C(k)C_{l_Q} + C_{l_A} \} + C_{l_0}$$
$C_{l_Q}$ is the circulatory part of the lift, which, at steady-state, is equal to $2\pi\alpha$. $C_{l_A}$ is the non-circulatory part that have to do with fluid inertia; at steady-state, its contribution would be zero. The last term is the camber contribution. $C(k)$ is the Theodorsen function, which serves as a complex gain on the circulatory part of the lift. $\text{Re}$ here refers to the real-part of the function, not Reynolds number.
The decrease in lift and lag is readily seen in the Theodorsen function, where $C(k)=F(k)+iG(k)$:
Ref: https://pdfs.semanticscholar.org/8457/c72b980f2f129a9f211617a5cdee4e162b75.pdf
The reduced frequency, $k=\frac{\omega c}{2V_\infty}$, denotes how many airfoil chord lengths per flow distance traveled in one motion period ($\omega$ is the angular frequency of the cyclic motion), and is a measure of how much the cyclical motion affects the flow on the airfoil. As $k \to 0$, there is no attenuation in lift and no phase lag; this is the quasi-steady aerodynamics. As $k$ increases, there is increasing attenuation in lift, up to 50%. The maximum phase lag occurs at $k \approx 0.25$.
For most rigid-body motions in commercial aircraft, the reduced frequency is low and the quasi-steady assumption is valid.
