23
I fly a C172 (fix pitch propeller) and when my instructor and I practice a simulated engine failure, we do not turn off the engine, instead we set the engine to idle.
In an actual engine failure, should I expect less range than with the engine in idle?
    $\begingroup$ Related-- aviation.stackexchange.com/questions/64394/… $\endgroup$ Jun 9, 2020 at 13:23
    $\begingroup$ You could make a "rate of descent" graph for various RPMs at your favorite approach speed while you were at it. Especially if you rent, idle RPM may vary for each plane. You should find a highest rate of descent somewhere where the prop is spinning, which could produce an "engine out/prop not spinning" rate of descent with a little power still in. Keep in mind prop may still "wind mill" even if the motor shuts down. This will produce the highest rate of descent (most net drag) at that airspeed (and weight). $\endgroup$ Jun 10, 2020 at 10:42
  • $\begingroup$ Yes, but if your engine fails there will be many other factors that you would have to consider (available landing sites with safe approaches and acceptable surface, wind, etc.) that the difference in range should not be a major decision factor. $\endgroup$
    – copper.hat
    Jun 12, 2020 at 6:17
22
Yes to some degree. It depends on the idle rpm, prop pitch, engine compression and your gliding speed, but if the engine is off but windmilling, there is substantial drag from the energy needed to windmill the prop without any help from the engine and it will knock some measurable amount off the glide ratio.
When it's idling, it might still be windmilling a bit if there is still a negative angle of attack on the blades. At some rpm just above idle, the prop's rotation speed will be at the zero thrust point (blade AOA at zero) and the glide will be like there is no prop there at all. To know where that is, you'd have to be able to measure the thrust load directly somehow. So it's quite a moving target, trying to come up with a gliding value with different conditions with a running engine.
With the engine off completely, the windmilling drag drag case is at its worst, and the best glide is achieved if the propeller can be stopped completely so that the blade is fully stalled with a near 90 deg AOA, but this is not something advocated in training.
A stationary fixed pitch propeller makes way less drag that one being driven around by airflow, which is effectively in an "autorotation" making substantial lift aft. You an visualize this by imagining an autogyro, which can descend vertically with the airflow going straight up through its rotor to drive it - it's windmilling - and the rotor creates enough lift to limit the gyro's descent rate to about 500 fpm. Make the rotor stop completely and the autogyro becomes a falling anvil. Turn the gyro 90 degrees, make the rotor really small, like propeller size, and there's your gliding 172.
Problem is, while it's theoretically beneficial to get the prop to stop, you usually have to slow down quite a lot, maybe close to stall speed, not a good idea at low altitude. And a tired engine with low compression might keep windmilling right down to the stall speed (and an engine with tight cylinders may stop windmilling right at glide speed - a nice bonus). Under a few thousand feet, there are too many risks and other priorities to bother with this just for the L/D improvement.
If the engine quit at a substantial altitude and glide distance was absolutely critical (like over the water and trying to make it back to shore), I might try slowing it down to get the prop to stop windmilling. How slow I have to go to get it to stop, and how fast I can go before it starts windmilling again depends on the cylinder compression in the engine, so it may work well or it may not, and I may have used up most of the benefit trying to get the thing to stop.
As a student pilot, don't go there on your own (thinking about slowing down to stop the prop) but it wouldn't hurt at all to ask for a demonstration at altitude to observe the glide performance with the prop windmilling vs stopped vs idling. You'd get some sense of the drag differences by noting the descent rate at the same airspeed for each case.
The above applies to fixed pitch propellers. If you have a constant speed prop (variable pitch, non feathering, and if it's feathering, like on a turboprop, well it's not an issue at all), it gets more nuanced. Normally if the engine quits the prop goes to full fine pitch with the blades nearly flat and it likely will stop windmilling at gliding speed. Some people argue that moving the prop control to full coarse (low RPM) before the oil pressure decays can get the blades to kind of "part way to feather" and this will reduce the drag of the prop to less than a stationary prop at full fine with the blades nearly flat. On the other hand, the coarse pitch might just get it windmilling... Hard to say without some testing.
  • $\begingroup$ You're right. I made some changes and added a para at the end, although I don't think we need to cover feathering single engine props on turbines, but I hope the clarifications help. Thanks. $\endgroup$
    Jun 9, 2020 at 17:37
  • $\begingroup$ Much better. Deleted my comment and upvoted. $\endgroup$ Jun 9, 2020 at 19:26
    $\begingroup$ Either the prop will windmill or it won't. If it is windmilling, then it's spinning the engine. If it windmills above programmed idle speed, the engine computer's idle-control system should turn off fuel injection altogether, since any use of fuel is a) unneeded and b) would increase speed even further beyond idle, and that's not the idle system's job. Your car does that approaching every traffic light. Well my car does and it's 25yo. $\endgroup$ Jun 10, 2020 at 15:04
  • $\begingroup$ Well first of all the poster's C-172 will have a Marvel Schebler carburetor, so if there is fuel and spark it's running and all the airflow will do is unload/backdrive the prop and raise the idle speed. And if it is injected, aircraft fuel injection systems are ancient technology mechanical continuous flow systems excepting the very latest FADEC piston engine systems you might see on some high end stuff. The regular stuff doesn't work that way. Airplanes still use magnetos that are similar to tractor mags from the 30s. In any case, we are mostly concerned with windmilling while failed. $\endgroup$
    Jun 10, 2020 at 19:52
  • $\begingroup$ @Harper-ReinstateMonica Most GA aircraft don't have FADECs. Or any sort of ECU. I'm 34 and I've literally never flown an airplane younger than I am. The newest one I've flown was built in 1980, but based on a design from the 60s. My experience is not particularly atypical in that regard for GA pilots, as far as I know. $\endgroup$
    – reirab
    Jun 11, 2020 at 17:14
The answer to this is a definite "maybe".
YouTube personality Trent Palmer tested this very question. He was actually able to glide further with the engine off than he was with it at idle. It was a very small gain, though, on the order of a few seconds extra flying time per 1,000 feet descent. The people he was with reported different results: One guy said he glided further with the engine at idle than with it off, but, again, the difference was miniscule. So, the ultimate answer is that it depends on your exact aircraft.
Edit: My answer originally said that everybody involved in the test got the same results. I was working from memory when typing this. Having rewatched the video, I see I was wrong in that, some people got different results (which actually illustrates the point better in my opinion).
  • $\begingroup$ I would bet that on any relatively draggy airframe like a Kitfox, or 172 for that matter, that the difference is maybe half a point in L/D if that. Probably a lot more of a difference on a fast composite a/c If you have a constant speed prop, and you think fast, it can be beneficial to pull the prop to MIN rpm while there is still residual oil pressure, and hopefully drive the blades to full coarse, getting you at least part way to feathered. On the other hand, the coarse blades may just windmill easier, making things worse. More testing required... $\endgroup$
    Jun 9, 2020 at 15:23
I feel that in most cases a partially powered prop will have a longer glide trajectory than a stationary or windmilling prop. Considering that when the prop is stationary, it effectively increases the frontal area of the aircraft, by the silhouette of the blades, but when windmilling, it in effect becomes a complete disk of drag, extracting energy that would otherwise be used to extend the glide.
In the case of a real engine failure, in a fixed pitch installation, windmilling or not becomes a case by case situation, depending on the nature of the failure. Further, there is a certainty that at sometime, the aircraft will get to the ground, with no chance of a go-around.
In a simulated engine failure, it is quicker, easier and more reliable to power up a warm idling engine than to initiate a restart of a potentially now very cold engine. Add to this, the associated costs of thermal shock resulting in cracked cylinder heads, is why simulated engine failures are simulated.
