I would like to know when the aircraft manufactures decide to put in practice their designs building the first scaled prototype (or maybe the actual size). Does the design have to accomplish a list of basic parameters or something like that?
There is no definite answer that will fit all manufacturers and projects for the question you're asking.
Simply put, the decision to create a scale model or a first prototype depends on what the goal of the creation is, the underlying technology, cost and market interest. A lot of aircraft, either new models or improved variants of already existing models never make it past the design stage. Other results in scale models to verify aspects of the underlying design or technology, while some may even skip this and go directly to a full-size prototype to be used for testing.
In some cases, a manufacturer will build a prototype regardless of market interest, because it allows them to showcase the technology and show that it actually works, while other manufacturers might not continue to that stage unless they have generated actual orders for the aircraft.
Needless to say these decisions will be based on different input from project to project, but generally speaking the end goal is to lower the risk if you decide to continue a project. If you are designing a very new aircraft, it makes sense to validate aspects of it before committing to production unless you can demonstrate that the risk is already low enough not to matter greatly.
| improve this answer | |
  • $\begingroup$ Some might only prototype the cabin as well, to get a feel for how the interior will feel. $\endgroup$ – CrossRoads Jun 7 at 20:56
  • $\begingroup$ Absolutely. I don't have any data on it, but I suspect mockups are more common than scale model or functioning prototypes due to cost. Having a mockup allows you to showcase a new model using cheap materials that are easy to work with, and it also allows you to iterate and gradually improve a design without committing too much resources to a project. $\endgroup$ – bjelleklang Jun 7 at 21:26
    $\begingroup$ Here's article on the Beech X700 mockup airfactsjournal.com/2018/04/… "the mockup of the X700 was destroyed and never saw the light of day" $\endgroup$ – CrossRoads Jun 7 at 21:33
