The planes I am talking about are everyday passenger plane's, not fighters. Do you know what the angle needs to be for it to create enough lift so the plane can fly?
$\begingroup$ Do you mean Angle of Attack? $\endgroup$ – Bianfable Jun 4 '20 at 11:50
$\begingroup$ I do. Thank you $\endgroup$ – Minecraft Noob Jun 4 '20 at 11:55
$\begingroup$ That helped a lot. thank you. $\endgroup$ – Minecraft Noob Jun 4 '20 at 11:58
The angle of attack airplanes fly at while cruising is called the optimum angle of attack (around 4 degrees) which meets the max.(L/D).
$\begingroup$ @TrentAlexanderArnold you're most welcome. $\endgroup$ – Hisham I هشام Jun 5 '20 at 13:11
